[gdal-dev] a possible memory leak in ogr\ogrsf_frmts\sqlite
Deyan Vasilev didomeister at gmail.com
Thu Feb 6 03:30:06 PST 2025
Hello,
it may be needed for sure for the whole session or at least if you
need the already registered extension to be available at the next db
open attempt.
A deeper look in sqlite3 gave me the sqlite3_shutdown() API that
actually frees the extension attached via
sqlite3_reset_auto_extension() together with various other sqlite3
stuff. I do not see GDAL to call sqlite3_shutdown() anywhere and I
think it is quite reasonable to do it in some GDAL sqlite driver
finalization steps - in the OGRSQLiteBaseDataSource destructor, in the
Close() method after closing db,  etc.
Deyan
On Thu, Feb 6, 2025 at 12:52 PM Even Rouault <even.rouault at spatialys.com> wrote:
> Deyan
> this sounds more like "still reachable" memory in Valgrind terminology
> (https://valgrind.org/docs/manual/faq.html#faq.deflost), that is memory
> that is allocated by some component, still reachable by it but never
> explicitly freed before the end of the process, and the amount of it
> doesn't grow over time. There are certainly many similar such patterns
> in GDAL or other libraries it uses, and I don't see that as a bug or
> something that requires code changes.
> Even
> Le 06/02/2025 à 11:34, Deyan Vasilev via gdal-dev a écrit :
> > Hello,
> > I was chasing for a long time a small 8 byte memory leak and was able
> > to identify it in the OGR sqlite extension binding, here's what I
> > observed:
> > A call to OGRSQLiteBaseDataSource::OpenOrCreateDB() would invoke
> > OGR2SQLITE_Register() and then sqlite3_auto_extension(). The latter is
> > a sqlite3 call that would malloc an 8 byte buffer for the extension
> > function entry point if the extension is unknown to sqlite3 (was not
> > previously registered).
> > This allocation seems to be unmanaged neither by sqlite3 nor by OGR
> > later causing an 8 byte memory leak.  I was able to resolve this by
> > adding a OGR2SQLITE_UnRegister() stub in ogrsqlitevirtualogr.cpp that
> > would call in a succession:
> > sqlite3_cancel_auto_extension ((void (*)(void)) OGR2SQLITE_static_register);
> > sqlite3_reset_auto_extension ();
> > and then have the OGR2SQLITE_UnRegister() stub called in
> > ogrsqlitedatasource.cpp \ OGRSQLiteBaseDataSource::CloseDB() right
> > after closing the database:
> >          sqlite3_close( hDB );
> >          hDB = nullptr;
> >          OGR2SQLITE_UnRegister();
> > This way the memory leak was gone. My app runs on VS2015/2019 with an
> > older GDAL release (2.4.4.) so the fix will be a bit different in 3.10
> > as the HAVE_SQLITE3EXT_H conditionals were not present in 2.4.4..
> > Best regards,
> > Deyan
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
