[gdal-dev] Issue Importing GML Files - HTTP 403
    Even Rouault
    even.rouault at spatialys.com
    Sun Feb  9 12:17:19 PST 2025
Andrea,
it would be best if the driver could access the schema, but this is not
a fatal error. It will try to guess it from the XML content it.
Even
Le 09/02/2025 à 20:58, andy via gdal-dev a écrit :
> Hi,
> I'm running the following loop to import GML files:
> for file in *_ple.gml; do
>   ogr2ogr --debug on -append -update -f gpkg CadastralParcel.gpkg
> "${file}" CadastralParcel;
> done
> This is one of these files:
> https://github.com/user-attachments/files/18725994/A094_AYAS_ple.gml.gz
> GDAL gives me this error:
> GML: Using Expat reader
> GML: Global SRS = urn:ogc:def:crs:EPSG::6706
> HTTP:
> Fetch(https://wfs.cartografia.agenziaentrate.gov.it/inspire/wfs/wfsUP.php?SERVICE=WFS&VERSION=2.0.0&REQUEST=DescribeFeatureType&TYPENAME=CP:CadastralParcel&OUTPUTFORMAT=application%2Fgml%2Bxml%3B%20version%3D3.2
> <https://wfs.cartografia.agenziaentrate.gov.it/inspire/wfs/wfsUP.php?SERVICE=WFS&VERSION=2.0.0&REQUEST=DescribeFeatureType&TYPENAME=CP:CadastralParcel&OUTPUTFORMAT=application%2Fgml%2Bxml%3B%20version%3D3.2>)
> HTTP: libcurl/7.88.1 OpenSSL/3.0.11 zlib/1.2.13 brotli/1.0.9
> zstd/1.5.4 libidn2/2.3.3 libpsl/0.21.2 (+libidn2/2.3.3) libssh2/1.10.0
> nghttp2/1.52.0 librtmp/2.3 OpenLDAP/2.5.13
> ERROR 1: HTTP error code : 403
> ERROR 1: Line 8: </BODY> doesn't have matching <BODY>.
> GML: Generating A094_AYAS_ple.gfs file, ignoring
> /vsimem/.#!HIDDEN!#./1/tmp_ogr_gml.xsd
> From what I understand, this happens because one of the URLs in the
> GML schema is not reachable:
> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
> http://www.opengis.net/wfs/2.0
> http://schemas.opengis.net/wfs/2.0/wfs.xsd
> http://www.opengis.net/gml/3.2
> http://schemas.opengis.net/gml/3.2.1/gml.xsd"
> My question is:
> - Is this "only" a formal issue, meaning that the files are probably
> correctly imported despite the error?
> - Or is it a blocking issue, and I should contact the data provider to
> fix the schema reference?
> Thanks in advance for your help,
> Andrea
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
>  in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250209/0c1ba05f/attachment.htm>
