[gdal-dev] config option to directly read zipped .gdb directories with file.zip extension?
    Even Rouault
    even.rouault at spatialys.com
    Mon Feb 10 13:20:54 PST 2025
Simon,
no, there's no way currently to work around your use case, but I feel we
should do something to support it. Please file an enhancement request at
https://github.com/OSGeo/gdal/issues/new?template=20_feature_request.yml
with the below information
Even
Le 10/02/2025 à 21:34, Simon Norris via gdal-dev a écrit :
> Hi,
> I'd like to read an OpenFileGDB directly with ogr via /vsicurl//vsizip, but the file is named <file>.zip
> Is there a config option I'm missing that will tell ogr that this is a valid zipped OpenFileGDB, or do I have to rename the file?
> $ ogrinfo /vsizip//vsicurl/https://maps.kamloops.ca/OpenData/zipfiles/ParksGDB.zip
> ERROR 4: `/vsizip//vsicurl/https://maps.kamloops.ca/OpenData/zipfiles/ParksGDB.zip' not recognized as being in a supported file format.
> ogrinfo failed - unable to open '/vsizip//vsicurl/https://maps.kamloops.ca/OpenData/zipfiles/ParksGDB.zip'.
> $ curl -o Parks.gdb.zip https://maps.kamloops.ca/OpenData/zipfiles/ParksGDB.zip
> $ ogrinfo Parks.gdb.zip
> INFO: Open of `Parks.gdb.zip'
>        using driver `OpenFileGDB' successful.
> thanks!
> Simon
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
