[gdal-dev] GDAL 3.10.2 release candidate available
    Even Rouault
    even.rouault at spatialys.com
    Tue Feb 11 12:27:17 PST 2025
Roger,
curl >= 7.68 was made a requirement for GDAL 3.9 per
https://gdal.org/en/stable/development/rfc/rfc98_build_requirements_gdal_3_9.html
a bit more than one year ago.
You can try to downgrade the minimum version by patching
https://github.com/OSGeo/gdal/blob/51ee2933c08896648613488926bff36939a66be7/cmake/helpers/CheckDependentLibraries.cmake#L29
and see if GDAL still builds with it. It might. This is just untested
territory. If that builds, that should be fine. If that doesn't, minor
patches might be needed.
Has it considered that R on Mac ships with a custom libcurl build that
is up to date ? After all, if you ship an up-to-date GDAL why not
shipping an up-to-date libcurl as well?
Even
Le 11/02/2025 à 21:00, Roger Bivand via gdal-dev a écrit :
> R-spatial for macOS static builds have run into a serious roadblock at
> 3.10.1, so maybe an early 3.10.2 could assist us.
> Until recently, static macOS builds of GDAL were using 3.5.3. Simon
> Urbanek (https://github.com/R-macos/recipes) has just converted the
> recipe for GDAL to cmake, and things were looking positive for 3.10.1,
> until we realised that:
> -- Found CURL:
> /Library/Developer/CommandLineTools/SDKs/MacOSX11.3.sdk/usr/lib/libcurl.tbd
> (found version "7.64.1")
>  checking whether CURLOPT_USERNAME is defined... yes
>  checking whether CURLOPT_PASSWORD is defined... yes
>  checking whether CURLOPT_KEYPASSWD is defined... yes
>  checking whether CURLINFO_RESPONSE_CODE is defined... yes
>  checking whether CURLOPT_BUFFERSIZE is defined... yes
>  checking whether CURLOPT_TCP_KEEPALIVE is defined... yes
>  checking whether libcurl is version 7.66 or later?... no
> so CURL is available but the MacOSX11.3.sdk version is insufficient -
> macOS 11.3 is the mandated build platform for R and R packages to
> accommodate most Darwin systems from older to newest.
> Building GDAL on the cmake step says:
> CURL component has been detected, but is disabled with GDAL_USE_CURL=OFF
> during the building of GDAL itself, leading to errors in downstream R
> software:
> GDAL/OGR not compiled with libcurl support, remote requests not
> supported.
> in sf and terra if opening resources via URL, and in potentially all
> the 1000+ packages using sf and terra. So unless this can be resolved,
> we'll probably have to go back to the last GDAL version not requiring
> >= 7.66 or whatever the threshold is and when it was changed.
> On the macOS side, it isn't practicable to upgrade the system library
> for distribution to many users.
> Is it possible to (optionally) specify a minimum CURL version of 7.64
> say when calling cmake in GDAL 3.10? If there is no such possibility
> now, could it be added to 3.10.2 (RC2)? Where should I look to try to
> add a prototype change?
> I didn't see a mention of the tightening of the CURL version
> requirement in the NEWS entries, but probably I'm looking in the wrong
> place.
> Best wishes,
> Roger
http://www.spatialys.com
