[gdal-dev] Debugging mask copy issues when using Band interleaved COGs
Owen Glofcheski
owen.glofcheski at gmail.com
Wed Feb 12 19:40:57 PST 2025
Hey all,
I work with Kurt Schwehr, and we've been debugging failures where an
explicit mask isn't preserved through a CreateCopy operation to create a
COG through the GTiff driver at HEAD.
This failure only started occurring after
https://github.com/OSGeo/gdal/commit/3bdc81a205bad8342688873e4ed5716f1208e8f5
After the CreateCopy, when we read back the mask, the mask is expanded from
the 1-bit mask to the 8-bit mask inside of gtiffoddbitsband.h. However, the
mask is not a 1-bit mask when I add logging here; instead, it's the
original 8-bit mask (with 255s and 0s). So when it gets expanded to 8-bits,
it's no longer the original mask:
E.g., 255 0 255 255 becomes 255 255 ... 255 255 0 0 ... 0 0 255 255 ...
So my guess is that somewhere along the line we either copy the mask
without turning it back into a bitmask, or we lose metadata tracking that
the mask is encoded a certain way.
Does anything obvious jump out to folks here? The issue *does not* occur
when either COPY_SRC_OVERVIEWS="YES" is removed or INTERLEAVE is set to
PIXEL (it only fails on band interleaving).
Here's a gist containing an example test that fails at head but previously
succeeded: https://gist.github.com/orglofch/40cf4d9136978b0384141cc74d1039b6
Thanks,
Owen
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250212/102a3a03/attachment.htm>
