[gdal-dev] gdalbuildvrt Max Value / Pixel Function
Daniel Baston
dbaston at gmail.com
Thu Feb 13 13:00:44 PST 2025
Hi Abdul,
For the specific case of multiple rasters that share the same extent, the
next release of GDAL should have a replacement "gdal_calc" that would take
multiple inputs and write a VRT that applies an expression to those inputs
("max", in your case). In the meantime, I think your best option would be
to prepare the VRT yourself.
Dan
On Thu, Feb 13, 2025 at 3:12 PM Abdul Raheem Siddiqui via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hello,
> I am looking for functionality to create a VRT of multiple rasters where
> the VRT pixel value is the maximum of underlying rasters pixel values.
> I found out that we have pixel functions
> https://lists.osgeo.org/pipermail/gdal-dev/2016-September/045134.html
> that we can add to VRTs to get this behavior but just checking to see if
> there is a direct way to specify this in gdalbuildvrt command line call or
> do one has to manually inject this in VRT xml.
> On the same note does the new gdaltileindex provide this functionality of
> selecting the max value for each pixel out of the box?
> Regards,
> ERT Inc.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250213/b171f1e8/attachment.htm>
