[gdal-dev] DXF ogr_style
    Michał Kowalczuk
    michkowalczuk at gmail.com
    Fri Feb 14 04:44:39 PST 2025
I found this const char *OGR_F_GetStyleString(OGRFeatureH)
<https://gdal.org/en/stable/api/vector_c_api.html#_CPPv420OGR_F_GetStyleString11OGRFeatureH>
which
is helpful,
but the question is still actual..
Is any option to force GDAL to create *ogr_style *field visible as normal
field (DXF dataset)?
Thanks in advance.
Michał
pt., 14 lut 2025 o 12:32 Michał Kowalczuk <michkowalczuk at gmail.com>
napisał(a):
> Dear GDAL devs,
> how can I force GDAL to generate *ogr_style* field when opening DXF
> dataset?
> Somewhere on the GitHub I read that this is a special field and it may be
> hidden... but how to make it visible?
> Regards,
> Michał Kowalczuk
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250214/c6e59a4b/attachment.htm>
