[gdal-dev] pansharpening on images with RPCs post GDAL 3.6
    Joe  McGlinchy
    joe at aidash.com
    Fri Feb 14 09:37:59 PST 2025
Hello,
I saw in the migration notes from GDAL 3.6 -> 3.7:
- Pansharpening now requires that panchromatic and multispectral bands have valid geotransform (in early versions, it was assumed in the case of missing   geotransform that they covered the same geospatial extent).  The undocumented VRT pansharpened MSShiftX and MSShiftY options (and the  corresponding C++ GDALPansharpenOptions::dfMSShiftX and dfMSShiftY members)  have been removed, due to using the inverted convention as one would expect,  and being sub-par solution compared to using geotransform to correlate pixels  of panchromatic and multispectral bands.
Previously, I had been taking a PAN and MS set of images with RPCs and running gdal_pansharpen, then copying over the RPCs from the PAN file, then continuing on in my workflow. This no long works past GDAL 3.6, so is there a recommended workflow for doing this? I've been able to "gdalwarp -rpc" the files prior to calling gdal_pansharpen, but i'd like to retain the image in image space with RPCs if possible.
thanks,
Joe
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250214/9e2d0dd2/attachment.htm>
