[gdal-dev] unsetting configs vs empty values
Laurențiu Nicola
lnicola at dend.ro
Tue Feb 18 22:26:20 PST 2025
To me, that's a bit unexpected and possibly a bug, but not a problem I've ever run into in practice. You're probably aware of this already, but instead of:
> export AWS_S3_ENDPOINT=...
> gdalmdiminfo ...
> unset AWS_S3_ENDPOINT
> gdalmdiminfo ...
you can do:
> AWS_S3_ENDPOINT=... gdalmdiminfo ...
> gdalmdiminfo ...
Laurentiu
On Wed, Feb 19, 2025, at 02:50, Michael Sumner via gdal-dev wrote:
> This may well just be a hapless user-question, can we set configs to empty and expect that to mean "unset"?
> In a fresh session all is well (standard public bucket):
> gdalmdiminfo /vsis3/mur-sst/zarr
> Our non-standard public bucket can't be found of course, so set the endpoint:
> export AWS_S3_ENDPOINT=projects.pawsey.org.au
> gdalmdiminfo /vsis3/idea-10.7289-v5sq8xb5/www.ncei.noaa.gov/data/sea-surface-temperature-optimum-interpolation/v2.1/access/avhrr/198109/oisst-avhrr-v02r01.19810901.nc
> but now
> ERROR 4: `/vsis3/mur-sst/zarr' not recognized as being in a supported file format.
> this fails, but I expected it to work:
> this succeeds:
> My question is what is the right way to revert the non-standard endpoint? We have to unset the option? Or, is an empty value a desirable way to mean "default"?
> Thanks for your help.
> Cheers, Mike
> Michael Sumner
> Research Software Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250219/bfbc1d8f/attachment.htm>
