[gdal-dev] libgeotiff 1.7.4 is released (Re: libgeotiff 1.7.4rc1 available for testing)
Even Rouault
even.rouault at spatialys.com
Wed Feb 19 02:23:27 PST 2025
promoted to final.
Download links:
- https://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.7.4.tar.gz
- https://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.7.4.zip
Even
Le 18/02/2025 à 15:58, Even Rouault via gdal-dev a écrit :
> Hi,
> Main reason: doesn't build with GCC 15
> Download links:
> https://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.7.4rc1.tar.gz
> - https://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.7.4rc1.zip
> Changelog:
> * CMake modernization, automate release generation from tags and
> refactor CI (#115)
> - CMake: Bumps the minimum CMake version to 3.13
> - CMake: Add BUILD_SHARED_LIBS matrix for ON and OFF using similar
> config for macos-latest, windows-latest, and ubuntu-latest
> - CMake: Modernize CMake configuration to prevent flag/feature leaking
> - CMake: Adds CPack configuration so `package_source` target is
> available for dist generation
> - CMake: Updates FindPROJ.cmake with GDAL's recent version
> - CMake: add BUILD_MAN and BUILD_DOC options
> - CMake: Windows PDB install with BUILD_SHARED_LIBS
> - CMake: Remove FindGeoTIFF.cmake
> - Removes 16 year old dead `makefile.mpw`
> - Removes 6 year old dead `makefile.vc`
> - CI: Generates release artifacts and attaches them to every build
> - CI: Creates a release and attaches release artifacts for every tag
> of the OSGeo/libgeotiff repository
> - CI: [Attests](https://github.com/actions/attest-build-provenance)
> the release artifacts if the `github.repository_owner == OSGeo`
> - CI: Remove Appveyor config
> * GTIFGetDefn(): add missing normalization of angular units to degree
> Contrary to what the documentation of GTIFDefn::ProjParm[] mentionned,
> we failed to normalize angular measures to degrees when reading them
> from projection parameters (ProjXXXXXGeoKey's) when
> ProjCoordTransGeoKey
> was present (but we did normalize them when reading them from the PROJ
> database when there were was only a EPSG PCS code)
> Relates to https://github.com/OSGeo/gdal/issues/10154 and
> https://github.com/OSGeo/gdal/pull/10158
> * Fix build with GCC 15 (#131)
> Even
http://www.spatialys.com
