[gdal-dev] link error with MrSID and ECW
Kai Pastor, DG0YT dg0yt at darc.de
Fri Feb 21 23:05:39 PST 2025
IMO you ask for trouble when you manually inject -DFRMT_mrsid=ON  into
CFLAGS and CXXFLAGS. This is CMake input ("ON"!). Let the configuration
do that for you. Did configuration successfully detect the dependency?
Check the config logs.
Kai
Am 22.02.25 um 05:15 schrieb Michael Katz via gdal-dev:
> I am getting the following link errors when building my application in
> MSVC++:
> 1>gdal.lib(gdalallregister.cpp.obj) : error LNK2019: unresolved
> external symbol _GDALRegister_ECW referenced in function
> _GDALAllRegister at 0
> external symbol _GDALRegister_JP2ECW referenced in function
> external symbol _GDALRegister_MrSID referenced in function
> I am linking statically to GDAL built as a static library with vcpkg
> (which builds without error). I am using a custom x86-windows.cmake
> file with vcpkg, customized mainly to include MrSID and ECW
> functionality in GDAL. I have pasted the cmake text at the bottom of
> this email.
> From what I can see in the GDAL code, it's behaving as if
> gdal/frmts/mrsid/mrsiddataset.cpp (which contains the function
> GDALRegister_MrSID) wasn't compiled into the library, yet the
> following code in frmts/gdalallregister.cpp was compiled.
> #ifdef FRMT_mrsid
>     GDALRegister_MrSID();
> #endif
> Can you help me understand how this could happen? What actually
> controls whether gdal/frmts/mrsid/mrsiddataset.cpp gets compiled into
> the library?
> x86-windows.cmake:
> set(VCPKG_TARGET_ARCHITECTURE x86)
> set(VCPKG_CRT_LINKAGE static)
> set(VCPKG_LIBRARY_LINKAGE static)
> set(VCPKG_BUILD_TYPE release)
> set(ENV{CMAKE_WINDOWS_KITS_10_DIR} "C:\\Program Files (x86)\\Windows
> Kits\\10")
> set(VCPKG_CMAKE_CONFIGURE_OPTIONS
> "-DCMAKE_WINDOWS_KITS_10_DIR=C:\\Program Files (x86)\\Windows Kits\\10")
> set(VCPKG_ENV_PASSTHROUGH CMAKE_WINDOWS_KITS_10_DIR)
> # CMAKE_CURRENT_LIST_DIR is the triplets directory
> # such as C:/Users/michael.katz/Documents/vcpkg/triplets
> message( STATUS "\n\n-----------------------CMAKE_CURRENT_LIST_DIR =
> ${CMAKE_CURRENT_LIST_DIR}\n\n" )
> if (PORT MATCHES "gdal")
>     string(
>         CONCAT x
> \"-DMRSID_INCLUDE_DIR=${CMAKE_CURRENT_LIST_DIR}/../sdk/MrSID_DSDK-9.5.5.5244-win32-vc17/Raster_DSDK/include\""
> \"-DMRSID_LIBRARY=${CMAKE_CURRENT_LIST_DIR}/../sdk/MrSID_DSDK-9.5.5.5244-win32-vc17/Raster_DSDK/lib/lti_dsdk.lib\""
> " \"-DGDAL_USE_MRSID=ON\""
> " \"-DFRMT_mrsid=ON\""
> \"-DECW_INCLUDE_DIR=${CMAKE_CURRENT_LIST_DIR}/../sdk/ecw/Hexagon/ERDAS_ECW_JPEG_2000_SDK_5.5.0/Desktop_Read-Only/include\""
> \"-DECW_LIBRARY=${CMAKE_CURRENT_LIST_DIR}/../sdk/ecw/Hexagon/ERDAS_ECW_JPEG_2000_SDK_5.5.0/Desktop_Read-Only/lib/vc141/Win32/NCSEcw.lib\""
> " \"-DGDAL_USE_ECW=ON\""
> " \"-DFRMT_ecw=ON\""
> "${VCPKG_CMAKE_CONFIGURE_OPTIONS} ${x}" )
>     set(VCPKG_CXX_FLAGS "${VCPKG_CXX_FLAGS} -DFRMT_mrsid=ON")
>     set(VCPKG_C_FLAGS "${VCPKG_C_FLAGS} -DFRMT_mrsid=ON")
>     set(VCPKG_CXX_FLAGS "${VCPKG_CXX_FLAGS} -DFRMT_ecw=ON")
>     set(VCPKG_C_FLAGS "${VCPKG_C_FLAGS} -DFRMT_ecw=ON")
> endif()
> message( STATUS
> "\n\n-----------------------VCPKG_CMAKE_CONFIGURE_OPTIONS =
> ${VCPKG_CMAKE_CONFIGURE_OPTIONS}\n\n" )
> message( STATUS "\n\n-----------------------FEATURES = ${FEATURES}\n\n" )
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250222/7bc7b8cb/attachment.htm>
