[gdal-dev] Zip-Compressed GeoJSON Files?
Simon Eves simon.eves at heavy.ai
Sun Feb 23 13:38:13 PST 2025
Oops. So it is. Thanks, Jukka!
On Sun, Feb 23, 2025 at 2:06 AM Rahkonen Jukka <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> I think this is documented in
> https://gdal.org/en/stable/user/virtual_file_systems.html#write-capabilities.
> At least after reading it I concluded that I must define both the zip file
> and the file to be inserted, and in that order.
> ogr2ogr -f "geojson" /vsizip/output.zip/geojson test.shp
> Test what I have
> ogrinfo /vsizip/output.zip
> INFO: Open of `/vsizip/output.zip'
>       using driver `GeoJSON' successful.
> 1: test (3D Multi Polygon)
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Simon
> Eves via gdal-dev
> *Lähetetty:* lauantai 22. helmikuuta 2025 3.31
> *Vastaanottaja:* gdal dev <gdal-dev at lists.osgeo.org>
> *Aihe:* Re: [gdal-dev] Zip-Compressed GeoJSON Files?
> Same with 3.10.1.
> On Fri, Feb 21, 2025 at 3:12 PM Simon Eves <simon.eves at heavy.ai> wrote:
> Revisiting our geo export options after several years and hit something
> weird.
> Testing with the command-line tools, this works...
> ogr2ogr -f "geojson" /vsigzip//path/to/output.geojson.gz <input>
> This does not...
> ogr2ogr -f "geojson" /vsizip//path/to/output.geojson.zip <input>
> It spits a ton of errors (attached) and while the zip file is created, it
> has no files in it.
> Am I doing something silly, or is this a bug?
> Does anyone really use or expect individually-zipped GeoJSON files anyway?
> This is with GDAL 3.7.3. We are updating to 3.11 so I'll try that too.
> Simon Eves
> Senior Rendering Engineer
> +1 (415) 902-1996
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250223/b234522e/attachment.htm>
