[gdal-dev] How to wrap a zarr in a zip and read it with vsizip?
Kurt Schwehr
schwehr at gmail.com
Wed Feb 26 22:27:15 PST 2025
Mike,
That's an interesting one for sure.
Even before the ESA talk of Zarr, we have a good amount of Zarr data
around. Just one I know of:
https://cloud.google.com/storage/docs/public-datasets/era5
On Wed, Feb 26, 2025 at 8:07 PM Michael Sumner <mdsumner at gmail.com> wrote:
> Just clueing into why you might be working with this, have you seen this
> critique? (was a bit shocked to see that this is apparently going forward
> for Sentinel 2, let alone that it was even considered!)
> https://github.com/csaybar/ESA-zar-zip-decision
> Also glad to see a working example outlined that I can follow, Thanks!
> Cheers, Mike
> On Tue, Feb 25, 2025 at 7:10 AM Kurt Schwehr via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
>> Thanks Laurentiu and Scott!
>> I can't believe 1) I left off -r and 2) I didn't think to look at what's
>> in the zip. Doh!
>> And thanks for reminding me about sozip. I was one of the reviewers of
>> the initial spec and still don't have it front-of-mind.
>> unzip -l nczarr_v2.zarr.zip
>> Archive: nczarr_v2.zarr.zip
>> Length Date Time Name
>> 0 2024-12-23 02:00 nczarr_v2.zarr/
>> 0 1 file
>> Now happily able to see the contents:
>> gdalinfo /vsizip/nczarr_v2.zarr.zip/nczarr_v2.zarr
>> Driver: Zarr/Zarr
>> Files: /vsizip/nczarr_v2.zarr.zip/nczarr_v2.zarr
>> Size is 512, 512
>> Subdatasets:
>> SUBDATASET_1_NAME=ZARR:"/vsizip/nczarr_v2.zarr.zip/nczarr_v2.zarr":/MyGroup/lon
>> SUBDATASET_1_DESC=Array /MyGroup/lon
>> SUBDATASET_2_NAME=ZARR:"/vsizip/nczarr_v2.zarr.zip/nczarr_v2.zarr":/MyGroup/lat
>> SUBDATASET_2_DESC=Array /MyGroup/lat
>> SUBDATASET_3_NAME=ZARR:"/vsizip/nczarr_v2.zarr.zip/nczarr_v2.zarr":/MyGroup/dset1
>> SUBDATASET_3_DESC=Array /MyGroup/dset1
>> SUBDATASET_4_NAME=ZARR:"/vsizip/nczarr_v2.zarr.zip/nczarr_v2.zarr":/MyGroup/Group_A/dset2
>> SUBDATASET_4_DESC=Array /MyGroup/Group_A/dset2
>> SUBDATASET_5_NAME=ZARR:"/vsizip/nczarr_v2.zarr.zip/nczarr_v2.zarr":/MyGroup/Group_A/dset3
>> SUBDATASET_5_DESC=Array /MyGroup/Group_A/dset3
>> [SNIP]
>> -Kurt
>> On Mon, Feb 24, 2025 at 11:21 AM Laurențiu Nicola via gdal-dev <
>>> I suspect it won't make a lot of difference. SOZIP is designed to allow
>>> seeking within a compressed file, but Zarr is tile- (block) based, where
>>> each of those is stored in a different file. So you end up uncompressing a
>>> whole file anyway.
>>> Laurentiu
>>> On Mon, Feb 24, 2025, at 21:17, Scott via gdal-dev wrote:
>>> > There's GDAL's sozip (Search Optimized Zip) utility as well. I have no
>>> > idea if it works with .zarr. I'm sure someone will correct me! ;)
>>> > cd nczarr_v2.zarr
>>> > sozip ../nczarr_v2.zarr.zip .
>>> > sozip -l /vsizip/../nczarr_v2.zarr.zip
>>> > On 2/24/25 10:09, Kurt Schwehr via gdal-dev wrote:
>>> >> Hi all,
>>> >> I seem to be having trouble exactly how to correctly make a zip of a
>>> >> zarr and how to correctly specify the vsizip url.
>>> >> e.g from autotest/gdrivers/data/zarr
>>> >> gdalinfo nczarr_v2.zarr # Works
>>> >> tar cf nczarr_v2.zarr.zip nczarr_v2.zarr
>>> >> Then what? I've tried lots of variations and not had any success.
>>> >> Thanks!
>>> >> -Kurt
>>> >> _______________________________________________
>>> >> gdal-dev mailing list
>>> >> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Michael Sumner
> Research Software Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250226/a2d009cf/attachment.htm>
