[gdal-dev] Motion: approve use of GSP funds for work on Conda build infrastructure
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Fri Jan 3 07:46:29 PST 2025
+1
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Even Rouault via gdal-dev
Lähetetty: torstai 2. tammikuuta 2025 16.54
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] Motion: approve use of GSP funds for work on Conda build infrastructure
Happy New Year to everyone!
PSC,
GDAL depends on conda-forge builds for a number of its continuous integration configurations, as well as offering builds of the master branch with the "gdal-master" conda channel
(https://gdal.org/en/stable/download.html#gdal-master-conda-builds)
which make them easily testable by users of the most common operating systems. We have identified a couple of points in the conda-forge infrastructure that are causing inconveniences to maintainers of the GDAL build recipe (and that also apply to other software package with similar complexity), in particular related to sub-package dependency pinning, and got a quote from Quansight to address them.
Motion: approve the use of up to 15,000 USD by Quansight for work on Conda build infrastructure, funded through the GDAL Sponsorhip program.
Starting with my +1,
Even
http://www.spatialys.com/
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
