[gdal-dev] Improving GDAL production in our release
Greg Troxel
gdt at lexort.com
Mon Jan 6 15:52:21 PST 2025
David Klaus <dklaus at carlsonsw.com> writes:
> Thank you for your fast response.
> Q: You didn't explain whether you are doing import/merge and carrying diffs
> to the sources, and if so, you didn't give a link where others can look at
> them.
> A: I apologize if I misunderstand your questions. I think you are asking
> whether or not anyone at our company has modified any of the source GDAL
> source files or if we are maintaining our own distribution of the source
> code. If this is the question, the answer is no.
That makes things easier.
> Q: You didn't publish a link to the scripts you are using.
> A: Personally, I have no problem with sharing the scripts we currently use.
> I will speak with my boss on whether it would be acceptable to share those
> here.
Having been at a large company, I understand. But nobody here will be
able to give you advice without reading your script. And, if you want
help making your build process better under nondisclosure, you'll need a
consultant rather than help from the list.
> Q: You didn't explain the problems you are having, just that it's hard.
> A: My apologies. The problem is that modifying our current scripts in order
> to produce a new build of GDAL takes a significant amount of development
> time. For example, I am currently working on building Proj-9.5.1 as part of
> our new GDAL build and I'm running into trouble linking "tiff" libraries.
> This is not likely irreconcilable but it takes time. I see how this can be
> difficult to understand without looking at our current build process. I
> will discuss this with my boss.
My quick guess is that you are reinventing a packaging system and that
the last 10% is hard. That's a little glib, but it sounds like various
paths. You might consider using a packaging system, and using a
different prefix than the regulsr /usr.
You may also want to be very rigorous and organized about -I and -L/-R
(-R may be spelled something like -Wl,-rpath).
> Q: I hope you are contributing funds to GDAL! I know that can be hard in a
> corporate environment....
> A: Of course I have no problem contributing my corporation's money to GDAL.
> Unfortunately, that's why I don't get to make those decisions. However, I
> will discuss this with my boss. Hopefully, I can persuade him,
You might consider how much the company would pay annually for a
proprietary license for code of equivalent breadth and quality to gdal,
proj, etc. You might look at Oracle's fees, or ESRI's. And then ask
management to take 10% of that and donate annually. What I have always
found is that companies are ok paying huge amounts of money for
proprietary licenses, but even with free software advocates inside, it's
amazingly difficult to donate.
> P.S. You mention the following:
> "I, and probably others, have scripts that basically set up -I/-L/-R for
> prereqs and run cmake, to be able to build/install-to-destdir/test various
> things. These are often only 100 lines, 2/3 comments, and don't cause me
> trouble."
> It sounds like your solution for generating up-to-date GDAL builds is
> rather streamlined. Currently we are working on updating our current build
> to GDAL 3.10.0. Were you to do the same how long would you estimate this
> update would take? Also, is there any chance you could share any of your
> scripts so I could compare them to ours?
This is not baked, and not up to date. For example it uses python 3.10
for docs, and while pkgsrc can still build that, I'm on 3.12 and
thinking about 3.13. It is not up to date because I haven't had to run
it lately. I am the maintainer of gdal in pkgsrc, and I update there,
and if that build works and passes tests, I don't need to build it
outside of pkgsrc. For a while I was chasing a few portability issues,
and some floating point stuff, but now there's very little trouble.
But, I am not statically linking, and I am living in a world where the
dependencies all come from pkgsrc. I typically build like this to check
git master for portability bugs that have crept in (test ==, assuming
things not required by POSIX, etc.) and to see if tests still pass (new
tests are added, and floating point is hard :-).
The last part is creating a distfile -- what the project would release
so I can run that through packaging.
Typically, for a new version, there's very little if anything I do. I'd
say if things build and test with no issues, it's 15 minutes of work.
If there are build/test issues, those dominate the effort and updating
the script is in the noise.
(I have similar scripts for autoconf projects; same concept different
spelling of build commands.)
#!/bin/sh
VERSION=3.6.0.dev0
if [ -d $HOME/bin/ccache ]; then
echo "enabling ccache"
ccache -z
PATH=$HOME/bin/ccache:$PATH
fi
PREFIX=/usr/pkg
LIBDIR=${PREFIX}/lib
# In theory, BSD make is ok.
MAKE=make
# \todo Debug poppler includes not found.
(rm -rf build destdir &&
mkdir build &&
cd build &&
cmake .. \
-LH \
-DCMAKE_COLOR_MAKEFILE=false \
-DCMAKE_INSTALL_PREFIX=${PREFIX} \
-DCMAKE_INSTALL_RPATH=${LIBDIR} \
> OUT.00.cmake 2>&1 &&
time ${MAKE} VERBOSE=1 > OUT.10.make 2>&1 &&
(time ${MAKE} check > OUT.20.check 2>&1 || true) && \
time ${MAKE} DESTDIR=../destdir install > OUT.30.install 2>&1 && \
echo BUILD DONE
## Create a distfile for pkgsrc testing.
# Set up tool variables.
export MAKE=gmake
export PYTHON=python3.10
export SPHINXBUILD=sphinx-build-3.10
# Remediate use of tools without search or variables.
PATH=/home/gdt/bin/GDAL:$PATH
(time ./mkgdaldist.sh ${VERSION} -url https://github.com/gdt/gdal > OUT.40.mkgdaldist 2>&1 &&
cp -p gdal-${VERSION}.tar.xz /usr/pkgsrc/distfiles &&
echo "COPIED DISTFILE")
