[gdal-dev] Improving GDAL production in our release
Robert Coup robert.coup at koordinates.com
Tue Jan 7 02:28:54 PST 2025
Depending on what you need, I've found using VCPKG (https://vcpkg.io/en/)
can make it straightforward to address the dependencies *of* GDAL, and it's
all driven by CMake underneath, like GDAL's builds. Importantly, it is well
tested and supported on Windows. That means you end up spending your time
on GDAL/PROJ rather than why libpng or another sub-dependency isn't
building properly.
And if you don't need to track GDAL/PROJ super-closely, VCPKG itself mostly
tracks recent releases (eg: right now GDAL 3.10 and PROJ 9.5.1). It does
have a bit of a learning curve though; and things like python bindings add
extra complexity.
HTH,
Rob :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250107/eca4ab09/attachment.htm>
