[gdal-dev] Can valid cloud-optimized geotiffs have non-sequential tile ordering?
Scott Henderson
scottyh at uw.edu
Tue Jan 7 05:52:37 PST 2025
I’m accustomed to GeoTiff files having row-wise sequential layout of image tiles (and I was under the impression that GDAL assumes this for merging range requests)?
But I recently noticed a lot of excess GET requests working with SRTM data that passes COG validation scripts:
> https://opentopography.s3.sdsc.edu/raster/SRTM_GL1/SRTM_GL1_srtm/N59W102.tif
These files seem to have TileOffsets scattered about (for example here is excerpt from tiffdump: TileOffsets (324) LONG (4) 64<2269213 2409502 3485315 2716342 …)
I believe this odd layout is causing the many GET requests to access this data, for example:
CPL_DEBUG=ON gdal_translate -srcwin 0 0 1024 512 /vsicurl/https://opentopography.s3.sdsc.edu/raster/SRTM_GL1/SRTM_GL1_srtm/N59W102.tif test.tif
Since a key aspect of COGs is efficient network access, shouldn’t this file not be considered a COG?
Scott Henderson
Research Scientist, Earth & Space Sciences
Data Science Fellow, eScience Institute
Johnson Hall 251
University of Washington
http://scottyhq.github.io
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250107/84f3a9c0/attachment.htm>
