[gdal-dev] GDAL 3.10.1 release candidate available
Even Rouault even.rouault at spatialys.com
Tue Jan 7 21:00:39 PST 2025
Hi Kai,
ok, I'm reverting PR 11314 for the 3.10 branch per
https://github.com/OSGeo/gdal/pull/11608 as the change is obviously too
invasive for a stable branch (Alessandro mentioned to me a similar issue
when building QGIS). I'm keeping it in master 3.11.0dev for now. I've
filed https://github.com/PDAL/PDAL/issues/4607 to PDAL
Even
Le 08/01/2025 à 05:32, Kai Pastor, DG0YT via gdal-dev a écrit :
> In vcpkg, I see downstream build errors for pdal, osgearth, gz-common5.
> This seems to be related the GDAL_DEBUG changes,
> https://github.com/OSGeo/gdal/pull/11314, in the context of forward
> declarations in non-gdal code. It is probably visible only in debug
> builds. (Vcpkg builds debug and release.)
> For pdal, the error is:
> FAILED: CMakeFiles/pdalcpp.dir/filters/CropFilter.cpp.o
> /usr/bin/c++ -DGDAL_DEBUG -DH3_PREFIX="" -DH5_BUILT_AS_STATIC_LIB
> -DPROJ_DLL="" -DUNIX -Dpdalcpp_EXPORTS
> -I/mnt/vcpkg-ci/b/pdal/src/2.8.3-5021054830.clean
> -I/mnt/vcpkg-ci/b/pdal/x64-linux-dbg/include
> -I/mnt/vcpkg-ci/b/pdal/src/2.8.3-5021054830.clean/vendor
> -I/mnt/vcpkg-ci/b/pdal/src/2.8.3-5021054830.clean/vendor/nlohmann
> -I/mnt/vcpkg-ci/installed/x64-linux/include/libxml2 -isystem
> /mnt/vcpkg-ci/b/pdal/src/2.8.3-5021054830.clean/vendor/kazhdan
> -isystem /mnt/vcpkg-ci/installed/x64-linux/include -isystem
> /mnt/vcpkg-ci/installed/x64-linux/include/eigen3 -isystem
> /mnt/vcpkg-ci/installed/x64-linux/include/utf8cpp -fPIC -g -std=c++17
> -fPIC -Wno-noexcept-type -Wno-class-memaccess -Wno-psabi
> -Wno-implicit-fallthrough -Wno-int-in-bool-context -Wno-dangling-else
> -Wall -Wextra -Wpointer-arith -Wcast-align -Wcast-qual
> -Wno-error=parentheses -Wno-error=cast-qual -Wredundant-decls
> -Wno-unused-parameter -Wno-unused-variable -Wno-long-long
> -Wno-unknown-pragmas -Wno-deprecated-declarations
> -fvisibility-inlines-hidden -fvisibility=hidden -MD -MT
> CMakeFiles/pdalcpp.dir/filters/CropFilter.cpp.o -MF
> CMakeFiles/pdalcpp.dir/filters/CropFilter.cpp.o.d -o
> CMakeFiles/pdalcpp.dir/filters/CropFilter.cpp.o -c
> /mnt/vcpkg-ci/b/pdal/src/2.8.3-5021054830.clean/filters/CropFilter.cpp
> In file included from
> /mnt/vcpkg-ci/installed/x64-linux/include/ogr_spatialref.h:20,
>                  from
> /mnt/vcpkg-ci/installed/x64-linux/include/ogr_geometry.h:23,
>                  from
> /mnt/vcpkg-ci/b/pdal/src/2.8.3-5021054830.clean/filters/private/Point.hpp:38,
>                  from
> /mnt/vcpkg-ci/b/pdal/src/2.8.3-5021054830.clean/filters/CropFilter.cpp:44:
> /mnt/vcpkg-ci/installed/x64-linux/include/ogr_srs_api.h:430:39: error:
> conflicting declaration ‘typedef struct OGRSpatialReferenceHS*
> OGRSpatialReferenceH’
>   430 | typedef struct OGRSpatialReferenceHS *OGRSpatialReferenceH;
> /mnt/vcpkg-ci/b/pdal/src/2.8.3-5021054830.clean/pdal/Polygon.hpp:39,
>                  from
> /mnt/vcpkg-ci/b/pdal/src/2.8.3-5021054830.clean/filters/CropFilter.hpp:41,
>                  from
> /mnt/vcpkg-ci/b/pdal/src/2.8.3-5021054830.clean/filters/CropFilter.cpp:35:
> /mnt/vcpkg-ci/b/pdal/src/2.8.3-5021054830.clean/pdal/Geometry.hpp:44:7:
> note: previous declaration as ‘using OGRSpatialReferenceH = void*’
>    44 | using OGRSpatialReferenceH = void *;
> The latter is from
> https://github.com/PDAL/PDAL/blob/master/pdal/Geometry.hpp#L44
> It doesn't reflect the impact of the former private DEBUG, now public
> GDAL_DEBUG.
> Kai
> Am 07.01.25 um 15:32 schrieb Even Rouault via gdal-dev:
>> Hi,
>> I have prepared a GDAL/OGR 3.10.1 release candidate.
>> Pick up an archive among the following ones (by ascending size):
>> https://download.osgeo.org/gdal/3.10.1/gdal-3.10.1rc1.tar.xz
>> https://download.osgeo.org/gdal/3.10.1/gdal-3.10.1rc1.tar.gz
>> https://download.osgeo.org/gdal/3.10.1/gdal3101rc1.zip
>> A snapshot of the gdalautotest suite is also available:
>> https://download.osgeo.org/gdal/3.10.1/gdalautotest-3.10.1rc1.tar.gz
>> https://download.osgeo.org/gdal/3.10.1/gdalautotest-3.10.1rc1.zip
>> The NEWS file is here:
>> https://github.com/OSGeo/gdal/blob/v3.10.1RC1/NEWS.md
>> Best regards,
>> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
