[gdal-dev] ExecuteSQL method to dependably remove features from datasource
Even Rouault even.rouault at spatialys.com
Wed Jan 8 11:28:11 PST 2025
Jesse,
> I seem to be able to remove features from a GPKG datasource using
> ExecuteSQL and “delete from layer_name where cond” style query with
> the SQLITE dialect.  For some of our use cases, this is quite a bit
> nicer than a manual loop in Python.
> Are there restrictions or other concerns that I should keep in mind
> when using this, beyond the recommendation to VACUUM afterwards to
> shrink the disk file down?
That is perfectly fine. There are triggers to update the spatial index
and the feature count.
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250108/77bf4e70/attachment.htm>
