[gdal-dev] Is it possible to write custom CRS WKTs within a GeoTiff?
David Shean dshean at uw.edu
Wed Jan 8 11:50:27 PST 2025
Thanks Even, and appreciate pointer to the GeoTIFF 2.0 spec discussion.
> "If you can sacrifice the ellipsoidal height axis to avoid using a Projected 3D CRS, which is a bit of a geodetic dubious object (don't ask me more, but minds more enlightned than me question the soundness of using an ellipsoidal heights with a projected CRS)”
I won’t ask you more :) but maybe this can be discussed further with those enlightened minds, perhaps on PROJ mailing list or a GH issue?
We’ve been exploring approaches to embed custom 3D CRS (both Geographic and Projected, with dynamic frame epoch definition), vertical datum information (essential), and data acquisition epoch for geotiff elevation products, with the hope of eliminating metadata ambiguity for future downstream integration and analysis.  But then we’ve also mistakenly failed to bundle/transfer the aux.xml sidecar files with some geotiffs, leading to downstream issues and confusion.
Would be great to hear any other thoughts on best practices and options using current and future versions of GDAL/PROJ/GeoTIFF.
David Shean
Civil and Environmental Engineering
University of Washington
https://www.ce.washington.edu/facultyfinder/david-shean
201 More Hall, Box 352700
3760 E. Stevens Way NE
Seattle, WA 98195-2700
Office: (206) 543-3105, Wilcox Hall 265
Pronouns: he, him, his
> On Jan 8, 2025, at 8:56 AM, Even Rouault via gdal-dev <gdal-dev at lists.osgeo.org> wrote:
> Scott,
>>  I’d like to be able to store a custom WKT *inside GeoTiff metadata* rather than in an external PAM file.
> GeoTIFF CRS encoding is a custom one, and doesn't support WKT  (there's some hypothetical idea of allowing/mandating WKT2 for an hypothetical GeoTIFF 2.0 spec : https://github.com/opengeospatial/geotiff/issues/56 <https://urldefense.com/v3/__https://github.com/opengeospatial/geotiff/issues/56__;!!K-Hz7m0Vt54!l1HH4-dmmtyU4CPsIRtDt1Zf3CKzVUwtIc5gEfUTGVSyawjmrWKSW2tTag1LjZRzNGr5WklsndhfJJQDy10$> )
> If you can sacrifice the ellipsoidal height axis to avoid using a Projected 3D CRS, which is a bit of a geodetic dubious object (don't ask me more, but minds more enlightned than me question the soundness of using an ellipsoidal heights with a projected CRS), then the driver will make a quite reasonable effort to encode it into GeoTIFF keys (you'll loose the comments, area of use, and DYNAMIC[] node in the process, although one could argue that the later should be automatically reconstructed by the GeoTIFF reader)
> Note: your ending remark uses a non-ASCII ” character, which prevents the WKT to be parsed.
> So given a test.wkt file with the following:
> PROJCRS["WGS84 (G1150) / UTM zone 12N",
>     BASEGEOGCRS["WGS 84 (G1150)",
>         DYNAMIC[
>             FRAMEEPOCH[2001]],
>         DATUM["World Geodetic System 1984 (G1150)",
>             ELLIPSOID["WGS 84",6378137,298.257223563,
>                 LENGTHUNIT["metre",1]]],
>         PRIMEM["Greenwich",0,
>             ANGLEUNIT["degree",0.0174532925199433]],
>         ID["EPSG",7661]],
>     CONVERSION["UTM zone 12N",
>         METHOD["Transverse Mercator",
>             ID["EPSG",9807]],
>         PARAMETER["Latitude of natural origin",0,
>             ANGLEUNIT["degree",0.0174532925199433],
>             ID["EPSG",8801]],
>         PARAMETER["Longitude of natural origin",-111,
>             ID["EPSG",8802]],
>         PARAMETER["Scale factor at natural origin",0.9996,
>             SCALEUNIT["unity",1],
>             ID["EPSG",8805]],
>         PARAMETER["False easting",500000,
>             LENGTHUNIT["metre",1],
>             ID["EPSG",8806]],
>         PARAMETER["False northing",0,
>             ID["EPSG",8807]],
>         ID["EPSG",16012]],
>     CS[Cartesian,2],
>         AXIS["(E)",east,
>             ORDER[1],
>             LENGTHUNIT["metre",1,
>                 ID["EPSG",9001]]],
>         AXIS["(N)",north,
>             ORDER[2],
>                 ID["EPSG",9001]]],
>     USAGE[
>         SCOPE["unknown"],
>         AREA["Between 114°W and 108°W, northern hemisphere between equator and 84°N, onshore and offshore. Canada - Alberta; Northwest Territories (NWT); Nunavut; Saskatchewan. Mexico. United States (USA)."],
>         BBOX[0,-114,84,-108]],
>     REMARK["Custom WKT2 combining UTM_12N with WGS84 (G1150)"]]
> $ gdal_translate in.tif out.tif -a_srs "$(cat test.wkt)"
> $ gdalinfo out.tif
>         ID["EPSG",7661]],
>     CONVERSION["Transverse Mercator",
>             ID["EPSG",9807]],
>             ID["EPSG",8801]],
>             ID["EPSG",8802]],
>             ID["EPSG",8805]],
>             ID["EPSG",8806]],
>             ID["EPSG",8807]]],
>     CS[Cartesian,2],
>         AXIS["easting",east,
>             ORDER[1],
>                 ID["EPSG",9001]]],
>         AXIS["northing",north,
>             ORDER[2],
>                 ID["EPSG",9001]]]]
> $ listgeo out.tif
> [... snip ... ]
>    Keyed_Information:
>       GTModelTypeGeoKey (Short,1): ModelTypeProjected
>       GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
>       GTCitationGeoKey (Ascii,29): "WGS84 (G1150) / UTM zone 12N"
>       GeographicTypeGeoKey (Short,1): Code-7661 (WGS 84 (G1150))
>       GeogCitationGeoKey (Ascii,15): "WGS 84 (G1150)"
>       GeogAngularUnitsGeoKey (Short,1): Angular_Degree
>       GeogSemiMajorAxisGeoKey (Double,1): 6378137
>       GeogInvFlatteningGeoKey (Double,1): 298.257223563
>       ProjectedCSTypeGeoKey (Short,1): User-Defined
>       ProjectionGeoKey (Short,1): Proj_UTM_zone_12N
>       ProjLinearUnitsGeoKey (Short,1): Linear_Meter
>       End_Of_Keys.
>    End_Of_Geotiff.
>> Here is a motivating example, using a WKT that specifies a specific WGS84 realization for a given UTM zone:
>> INPUT=https://opentopography.s3.sdsc.edu/raster/COP30/COP30_hh/Copernicus_DSM_10_N38_00_W109_00_DEM.tif <https://urldefense.com/v3/__https://opentopography.s3.sdsc.edu/raster/COP30/COP30_hh/Copernicus_DSM_10_N38_00_W109_00_DEM.tif__;!!K-Hz7m0Vt54!l1HH4-dmmtyU4CPsIRtDt1Zf3CKzVUwtIc5gEfUTGVSyawjmrWKSW2tTag1LjZRzNGr5WklsndhfYx7Qu_8$>
>> OUTPUT=/tmp/Copernicus_DSM_10_N38_00_W109_00_DEM_UTM.tif
>> CPL_DEBUG=ON \
>>  GDAL_DISABLE_READDIR_ON_OPEN=EMPTY_DIR \
>>  gdalwarp -co GEOTIFF_VERSION=1.1 -overwrite -dstnodata 0 -r bilinear -tap -tr 30.0 30.0 -s_srs EPSG:7661 -t_srs utm12N_wgs1150.wkt $INPUT $OUTPUT
>> Here is the wkt, I’d like for it not to end up in a sidecar file where I might loose it, but embedded in the GTiff:
>>         DYNAMIC[
>>             FRAMEEPOCH[2001]],
>>         ID["EPSG",7661]],
>>             ID["EPSG",9807]],
>>             ID["EPSG",8801]],
>>             ID["EPSG",8802]],
>>             ID["EPSG",8805]],
>>             ID["EPSG",8806]],
>>             ID["EPSG",8807]],
>>         ID["EPSG",16012]],
>>     CS[Cartesian,3],
>>         AXIS["(E)",east,
>>             ORDER[1],
>>                 ID["EPSG",9001]]],
>>         AXIS["(N)",north,
>>             ORDER[2],
>>                 ID["EPSG",9001]]],
>>         AXIS["ellipsoidal height (h)",up,
>>             ORDER[3],
>>                 ID["EPSG",9001]]],
>>     USAGE[
>>         SCOPE["unknown"],
>>     REMARK["Custom WKT2 combining UTM_12N with WGS84 (G1150)”]]
>> Cheers,
>> Scott
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://urldefense.com/v3/__https://lists.osgeo.org/mailman/listinfo/gdal-dev__;!!K-Hz7m0Vt54!l1HH4-dmmtyU4CPsIRtDt1Zf3CKzVUwtIc5gEfUTGVSyawjmrWKSW2tTag1LjZRzNGr5Wklsndhflk8ZnOQ$>
> http://www.spatialys.com <https://urldefense.com/v3/__http://www.spatialys.com__;!!K-Hz7m0Vt54!l1HH4-dmmtyU4CPsIRtDt1Zf3CKzVUwtIc5gEfUTGVSyawjmrWKSW2tTag1LjZRzNGr5WklsndhfQhOfbpw$>
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250108/95b37cdf/attachment-0001.htm>
