[gdal-dev] Vector area calculation
    Even Rouault
    even.rouault at spatialys.com
    Fri Jan 10 08:52:56 PST 2025
I suspect you are running into
https://gdal.org/en/stable/tutorials/osr_api_tut.html#crs-and-axis-order
Concretely try adding:
source_srs.SetAxisMappingStrategy(osr.OAMS_TRADITIONAL_GIS_ORDER)
at line 34.
Even
Le 10/01/2025 à 17:49, ky via gdal-dev a écrit :
> Hello all, hope you are well
> Got some unexpected results computing area using GDAL==3.4.1 and
> official Brazilian projection, where results are about half of what is
> reported as correct. Does anyone knows what is causing it ?
> Just to compare shapely/geopandas yields correct results using same
> projections.
> code can be found on this gist:
> https://gist.github.com/rupestre-campos/a82a1403cb47a8153f07c775d7902f50
> the linked scrip outputs
> Area ha farm: 6.0
> Area ha calculated (gdal): 3.23
> Area ha calculated (geopandas): 6.0
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250110/192ce70c/attachment.htm>
