[gdal-dev] Issue with Robinson projection
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Jan 13 15:10:57 PST 2025
https://spatialreference.org/ref/esri/54030/
On Tue, 14 Jan 2025, 00:08 Even Rouault via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> Le 13/01/2025 à 23:36, afernandez via gdal-dev a écrit :
> Hello,
> The following snippet works fine
> #        epsg = 54030
>         epsg = 4326
>         srs = osr.SpatialReference()
>         srs.ImportFromEPSG(epsg)
> However, and when I switch epsg to 54030 (which I believe it's the value
> for the Robinson projection), it generates the error:
>   File "/usr/lib/python3/dist-packages/osgeo/osr.py", line 772, in
> ImportFromEPSG
>     return _osr.SpatialReference_ImportFromEPSG(self, *args)
> RuntimeError: PROJ: proj_create_from_database: crs not found
> 54030 is not a EPSG CRS but a ESRI one, so use
> srs.SetFromUserInput("ESRI:54030")
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250114/3e0c94ad/attachment.htm>
