[gdal-dev] Killing useless write side of drivers
Even Rouault
even.rouault at spatialys.com
Sun Jan 19 06:00:30 PST 2025
Andrew,
| one might think that the purpose of GDAL was to allow conversion
between geospatial data formats.
The ones that are still of use for someone
> I would prefer it if that was extended to include other purposes,
> rather than actually removing that as a significant purpose of GDAL.
Sorry, I haven't understood what you suggest exactly.
> I note that this email has already provoked the removal
> of one *read-only* driver - https://github.com/OSGeo/gdal/pull/11684
We don't remove drivers that have an evidence of being used, just the
ones that we strongly suspect that they are not or very little used.
This is no different than GCC killing obsolete architectures or the
Linux kernel removing unused or *unmaintained* drivers or architectures.
Contrary to those projects, the vast majority of GDAL drivers don't have
active maintainers to baby sit them. So if users don't speak up and
maintainers don't show up, we are reduced to guessing, and obviously we
can be wrong in our guessing, so be it. The only way of being sure would
be to have some telemetry, but obviously we aren't going to do that.
Some drivers have been written 25 years ago for interoperability with
software that might not be around anymore, or for users that have moved
to something else. Current maintainer team has no experience with most
of those formats. A number of the obscure ones might not have any unit
test. For example, yesterday, following my RFC105 changes, I fixed an
oss-fuzz discovered regression I caused in the JAXAPalsar driver. So I
was: "ok, let's run the unit tests. Oh wait, there is none!" So this
driver might work, or not. All those drivers also increase the
vulnerability surface of the project, increase compilation time which is
a pain for developers, etc, so there's a lot of reasons to do clean ups.
> If we are going to be more selective in which data fromats we support,
> what can we do to make easier to build out-of-tree drivers as plugins ?
> For example could github build gdal packages which other, third-party,
> github projects could pull in as a base to build these ?
Sorry, didn't get what you meant. I believe building out of tree drivers
for GDAL is reasonably easy.
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
