[gdal-dev] UTM local correction for height and distance-to-reference-meridian ?
Even Rouault even.rouault at spatialys.com
Tue Jan 21 07:23:34 PST 2025
> Now the same with ogrinfo. I simplified the SQL by  saving the test
> linesting into a file in EPSG:3067.
> ogrinfo -dialect sqlite -sql "select ST_Length(geometry) from length"
> length.json
> 208808.794960845
> Good so far. But with “use_ellipsoid” gives very unexpected result:
> ogrinfo -dialect sqlite -sql "select ST_Length(geometry,1) from
> length" length.json
> 417750.100376289
> Same wrong result also with this:
> ST_Length(ST_Transform(geometry,4326),1) from length" length.json
> length.json is this:
Jukka,
Thanks for the feedback. ST_Length(geometry, use_ellipsoid=1) is indeed
seriously broken in GDAL 3.10 as it only properly works on closed
linestrings / polygons
Fix in https://github.com/OSGeo/gdal/pull/11700
With it,
$ ogrinfo -dialect sqlite -sql "select ST_Length(geometry, 1) from test"
test.json -al -q
Layer name: SELECT
OGRFeature(SELECT):0
   ST_Length(geometry, 1) (Real) = 208875.050188144
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250121/06e8137a/attachment.htm>
