[gdal-dev] adding points to geometries
Scott
public at postholer.com
Sun Jan 26 08:33:03 PST 2025
Hey Javier,
Maybe create 2 geometries, southern and northern hemisphere, then do an
intersection of both with your source geometries. You would have to
create new fid as the new geom's would the same fid. Untested, something
like this:
ogr2ogr -dialect sqlite -sql @newGeom.sql target.gpkg source.gpkg
newGeom.sql
select
r.fid
,r.geom
from (
select
fid
,st_intersection(MakeCircle(0, 90, 4326, .001), geom) as geom
from mygeoms
union all
select
fid
,st_intersection(MakeCircle(0, -90, 4326, .001), geom) as geom
from mygeoms
) r
Hope that helps,
Scott
On 1/26/25 02:14, Javier Jimenez Shaw via gdal-dev wrote:
> Hi
> I have a vector layer (like /usr/share/qgis/resources/data/
> world_map.gpkg) and I need to add a point at latitude 0 for every
> segment (in line or polygon) that crosses the equator.
> How can I do it?
> Thanks,
> Javier.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
