[gdal-dev] using gdal.Warp to reproject a GTiff with an external nodata mask (.msk)
Even Rouault
even.rouault at spatialys.com
Mon Jan 27 08:04:37 PST 2025
Maxime,
you need to do in 2 steps, with something like (didn't test, slight
modifications may be needed):
- slightly modify your first step, to reproject to an intermediate RGBA
dataset, with dstAlpha=yes. That temporary dataset may be a VRT, or a
GeoTIFF with a lossless compression (ie DEFLATE)
- convert from RGBA to RGB+mask with gdal.Translate(out,
tmp_dataset_of_previous_step, bandList=[1,2,3], maskBand=4,
creationOptions=["COMPRESS=JPEG", "PHOTOMETRIC=YCBCR", "TILED=YES",
"BIGTIFF=YES"])
Even
Le 27/01/2025 à 16:58, Maxime Demers via gdal-dev a écrit :
> Hi everybody, I hope you are all well!
> I have an issue that I would need help about if possible.
> I would like to use the GDAL Python bindings to reproject a TIFF that
> has an external nodata mask stored in a separate |.msk| file. Also,
> this is important to me to keep the jpeg compression.
> After some tests, I found out that |gdal.Warp| does not reproject the
> |.msk|
> Is there a way to acheive what I am trying to do?
> |import os from osgeo import gdal IN_RASTER = os.path.join(r"C:\\",
> "data", "Ortho", "Ortho2024_32187_10cm_mask.tif") OUT_RASTER =
> os.path.join(r"C:\\", "data", "Ortho", "Ortho2024_3857_10cm_mask.tif")
> src = gdal.Open(IN_RASTER) dst = gdal.Warp( OUT_RASTER, src,
> format="GTiff", dstSRS="EPSG:3857",
> "BIGTIFF=YES"], callback=gdal.TermProgress_nocb ) dst = None|
> *Maxime Demers*
> Analyste en géomatique
> Service de la planification
> et de la gestion du territoire
> Tél. : 819 823-8000 poste 2360
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
"De l'égo à l'égoût, il n'y a qu'une bouche mal refermée", André Isaac
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250127/48693b10/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250127/48693b10/attachment.png>
