[gdal-dev] CSharp bindings queued for removal (was Re: GDAL CSharp bindings maintainers/contributors listening... ?)
    Even Rouault
    even.rouault at spatialys.com
    Tue Jan 28 20:32:39 PST 2025
Hearing silence, the only logical conclusion is that there is no
interest ==> https://github.com/OSGeo/gdal/pull/11746
Le 27/09/2024 à 20:15, Even Rouault via gdal-dev a écrit :
> Hi,
> This is your regular remainder that nobody in the core GDAL maintainer
> team is a CSharp aficionado (we don't have a personal grief against
> it, just that we are blatantly ignorant, at least speaking for myself
> !), so related tickets about it will definitely result in no action.
> See
> https://github.com/OSGeo/gdal/issues?q=is%3Aissue+is%3Aopen+label%3A%22csharp+bindings%22
> The current trend is that people seem to be annoyed by UTF-8 related
> issues. The issue is likely that our methods that accept or take a
> const char* in the SWIG bindings should use a specific typemap to map
> to CSharp Unicode strings instead of the "C" one or whatever those
> concepts are called in CSharp. There is an existing "utf8_path"
> typemap that is used in method that accept filenames, that should
> probably be renamed to utf8_string and be used more extensively. And
> probably with a version of the methods to also return a raw C string /
> bytearray in the cases where drivers don't know the encoding and might
> return "random" stuff. Cf pull request #10652 where I did something
> for Java that suffered from that later issue.
> Happy pull requests!
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Grumpy maintainer.
"De l'égo à l'égoût, il n'y a qu'une bouche mal refermée", André Isaac
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250129/6ffc2d44/attachment.htm>
