[gdal-dev] Missing GDALMemDataset , GDALDatasetRasterIOEx , VSIMem when GDAL is built with CSHARP Bindings
Paul Harwood
runette at gmail.com
Fri Jan 31 05:39:05 PST 2025
see Line 751 ++ for the list of build targets
On Fri, 31 Jan 2025 at 13:38, Paul Harwood <runette at gmail.com> wrote:
> https://github.com/OSGeo/gdal/blob/master/swig/csharp/CMakeLists.txt
> On Fri, 31 Jan 2025 at 13:36, Parveen Sharma <sharma1981 at outlook.com>
> wrote:
>> Thanks
>> Could you please point me to the relevant scripts?
>> *From:* Paul Harwood <runette at gmail.com>
>> *Sent:* Friday, January 31, 2025 9:31 PM
>> *To:* Parveen Sharma <sharma1981 at outlook.com>
>> *Cc:* Michał Kowalczuk via gdal-dev <gdal-dev at lists.osgeo.org>
>> *Subject:* Re: [gdal-dev] Missing GDALMemDataset , GDALDatasetRasterIOEx
>> I have checked and the three .csproj projects that you listed are NOT
>> currently being build by the build scripts - because they are not needed
>> for the test scripts. You will need to build them yourself.
>> On Fri, 31 Jan 2025 at 13:23, Paul Harwood <runette at gmail.com> wrote:
>> The first question that I would ask is what are you trying to achieve?
>> DBUILD_APPS=ON will build the standard GDAL apps but does not affect the
>> C# trial apps. I think this is the default anyway
>> DBUILD_CSHARP_BINDINGS=ON will build the c# bindings and the c# trial
>> apps. If that is what you are trying to do this should be sufficient.
>> The directory structure is actually dependent on what is created by
>> `dotnet` and can vary a little between platforms but sounds about right.
>> I have a feeling that when we went to cmake builds, the three apps you
>> mentioned mighted have been removed from the build scripts since they are
>> not used by the test scripts. I will check but, since they are csproj
>> projects you should anyway be able to just build them on top of the
>> bindings using `dotnet`.
>> On Fri, 31 Jan 2025 at 12:56, Parveen Sharma via gdal-dev <
>> gdal-dev at lists.osgeo.org> wrote:
>> Hi
>> I am building GDAL Master branch (
>> https://github.com/OSGeo/gdal/tree/master/swig/csharp/apps) using CMAKE.
>> I am using below flags to build the CSHARP Bindings
>> <arg value="-DBUILD_CSHARP_BINDINGS=ON"/>
>> <arg value="-DBUILD_APPS=ON"/>
>> However,
>> 1. I notice that in "*RelWithDebInfo*" build mode there is NO "*apps*"
>> folder generated in "RelWithDebInfo\swig\csharp" folder. I do see
>> individual apps folder like "GDALCreateCopy", "GDALDatasetWrite",
>> "GDALInfo" generated though. Is this expected?
>> 2. I DO NOT see the any folder corresponding to *GDALMemDataset ,
>> GDALDatasetRasterIOEx , VSIMem *in my "RelWithDebInfo\swig\csharp"
>> folder even though the source file is present at
>> https://github.com/OSGeo/gdal/blob/master/swig/csharp/apps/GDALMemDataset.cs
>> https://github.com/OSGeo/gdal/blob/master/swig/csharp/apps/GDALDatasetRasterIOEx.cs
>> https://github.com/OSGeo/gdal/blob/master/swig/csharp/apps/VSIMem.cs
>> *Am I missing any additional CMAKE Flags. Can you please let me know?*
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250131/6a69f974/attachment.htm>
