[gdal-dev] CSharp bindings queued for removal (was Re: GDAL CSharp bindings maintainers/contributors listening... ?)
Daniel Evans daniel.fred.evans at gmail.com
Fri Jan 31 07:04:22 PST 2025
> Middle ground: Make the download/installation of the SWIG bindings opt-in
only. We could at least track the number of users who go to the trouble of
downloading it.
I suspect those numbers are already (mostly) there, as most users of the
bindings likely don't download and compile GDAL themselves - they get a
package from their language's favourite package manager. Earlier in the
thread, Tamas was able to reel off some Nuget package manager numbers for
the C# bindings. One could do the same in Python via Conda or PyPI for
"gdal" / "rasterio" / "fiona", in R via <the R package manager> for rgdal,
and so on.
Daniel
On Fri, 31 Jan 2025 at 14:56, David Strip via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> On 1/31/2025 7:18 AM, Even Rouault via gdal-dev wrote:
> - less provocative: add telemetry. obviously not opt-in because nobody
> would take the time to turn it on, but just opt-out
> While this is a great solution in terms of accurate knowledge of use, I
> can already hear the comments regarding privacy, proxies, etc.
> downloading it.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250131/afe220ad/attachment.htm>
