[gdal-dev] GDAL DLL naming convention
Parveen Sharma
sharma1981 at outlook.com
Fri Jan 31 07:17:01 PST 2025
Thanks so sharing this information.
Sent: Friday, January 31, 2025 11:07 PM
To: Parveen Sharma <sharma1981 at outlook.com>
Cc: Michał Kowalczuk via gdal-dev <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] GDAL DLL naming convention
Parveen,
My company builds with vcpkg so this might not be applicable to you. But using the DGDAL_LIB_OUTPUT_NAME option I am able to specify the name of the output dll and lib file for our build. Here is how I set this option for our build:
-DGDAL_LIB_OUTPUT_NAME=gdal3100
This worked for us for both our current 3.10.0 build and a past 3.7.0 build. Hopefully this helps,
On Fri, Jan 31, 2025 at 9:59 AM Parveen Sharma via gdal-dev <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>> wrote:
Hello
Were in past GDAL DLLs were named with version in them when built from source ? For e.g. gdal303.dll
If yes, then is there any way to achieve the same now?
Best regards,
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
David Klaus
Carlson Software
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250131/7523d9f4/attachment.htm>
