[gdal-dev] Building GDAL from VCPKG fails with FreeXL
Kai Pastor, DG0YT
dg0yt at darc.de
Tue Jul 1 12:42:40 PDT 2025
- The freexl port builds in vcpkg CI, and there are no open issues for
Windows.
- Either there are log files for the actual error, reported on the
console, or it fails early for example because of mixing different
msys2/cygwin runtimes.
- freexl is an optional feature of port gdal. If nothing asks for it, it
is not enabled in port gdal.
- However, libspatialite is a default feature of port gdal, and freexl
is a default feature of port libspatialite. ATM it is not possible to
opt-out from libspatialite[freexl], but this will be fixed with port
gdal 3.11.1.
- To opt-out from all default features of a port, you must declare this
in the top-level manifest (manifest mode) or by using the pseudo feaure
"core" (classic mode). The reason why you can't do this now with
libspatialite[core] is that gdal[libspatialite] implicitly depends on
the default features of port libspatialite.
Kai Pastor
Am 29.06.25 um 19:11 schrieb Martin Chapman via gdal-dev:
> Even,
> I didn’t save the exact message but it was fairly non descriptive. It
> was something like BUILD_FAILED. Sorry, my bad for not saving the
> exact message. It sounds like it may have just been my environment
> and if it’s not critical then I can live without it. If no one else
> is complaining then I wouldn’t waste time looking into it. If I have
> time later I will try to rebuild and reproduce the error, it just
> takes an hour to build so can’t do it right now. Thanks for your help
> though!
> Best regards,
> Martin Chapman
> *From:*Even Rouault <even.rouault at spatialys.com>
> *Sent:* Sunday, June 29, 2025 3:33 AM
> *To:* mchapman at hyperacktive.com; gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] Building GDAL from VCPKG fails with FreeXL
> Martin,
> what error messages did you get when trying with FreeXL ?
> Removing the FreeXL dependency removes support for the old
> prior-to-Excel-2007 binary XLS format. So usually not a big deal
> Even
> Le 29/06/2025 à 02:45, Martin Chapman via gdal-dev a écrit :
> All,
> I tried to build GDAL 3.11.0 from https://vcpkg.io/en/package/gdal
> and FreeXL kept failing on my Windows 11 box using Microsoft
> Visual Studio Professional 2022 (64-bit) – Current Version
> 17.14.7. To resolve the issue I built a custom-overlay port and
> removed FreeXL from the build and then everything built great. I
> tried to just build FreeXL using VCPKG and that failed so I was
> wondering if it’s just my machine that is messed up or are others
> having issues as well? By removing FreeXL will I be crippling any
> other drivers that may depend on it? I looked at the docs and it
> didn’t seem that important? Also, is there a way to specify what
> drivers not to build without doing a custom-overlay port?
> Best regards,
> Martin Chapman
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250701/34ebe5ce/attachment.htm>
