[gdal-dev] array dim permute
Michael Sumner
mdsumner at gmail.com
Thu Jul 3 15:48:42 PDT 2025
I'm confused about the orientation of this in 2D mode 1485x1272 is correct,
with 122 bands.
(requires earthdata auth)
gdal raster info "/vsicurl/
https://obdaac-tea.earthdatacloud.nasa.gov/ob-cumulus-prod-public/PACE_OCI.20250501T234515.L2.SFREFL.V3_0.nc"
--output-format text | grep /rhos
# SUBDATASET_1_NAME=NETCDF:"/vsicurl/
":/geophysical_data/rhos
# SUBDATASET_1_DESC=[1485x1272x122] /geophysical_data/rhos (32-bit
floating-point)
If we drill into the rhos sds X becomes unrolled as the 1485 bands:
gdal raster info "vrt:///vsicurl/
https://obdaac-tea.earthdatacloud.nasa.gov/ob-cumulus-prod-public/PACE_OCI.20250501T234515.L2.SFREFL.V3_0.nc?sd_name=/geophysical_data/rhos"
--output-format text | grep "Size"
#Size is 122, 1272
We can (redundantly??) cast via mdim to get 1485x1272, but then we've lost
the geolocation arrays:
https://obdaac-tea.earthdatacloud.nasa.gov/ob-cumulus-prod-public/PACE_OCI.20250501T234515.L2.SFREFL.V3_0.nc?transpose=/geophysical_data/rhos:0,1"
#Size is 1485, 1272
At any rate in the default case the geolocation arrays don't match the data
orientation.
Cheers, Mike
Michael Sumner
Ordinary Member, Streets People Love Hobart Association
Research Software Engineer
Australian Antarctic Division
Hobart, Australia
0438489030
e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250704/d20dc632/attachment.htm>
