[gdal-dev] Can GDAL driver be reused by GDAL python binding
Even Rouault even.rouault at spatialys.com
Mon Jul 7 14:23:05 PDT 2025
Connection pooling is an internal implementation driver of each driver.
You have to be careful about multi-threaded use cases if you want to
implement that though. The PostGISRaster driver has some connection
pooling. See PostGISRasterDriver::GetConnection()
Even
Le 07/07/2025 à 21:18, Fengting Chen via gdal-dev a écrit :
> Hi,
> A Python program can invoke GDAL driver through gdal.open() to
> read/write raster/vector data. Is it possible for the GDAL driver to
> be reused in order to avoid reinitializing the driver for each
> gdal.open() call? For example, if a GDAL driver to a database
> implements a connection pool, will each gdal.open() call be able to
> ask the driver to retrieve a db connection from the connection pool,
> instead of creating a new database connection?
> Thanks!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250707/e1129b31/attachment-0001.htm>
