[gdal-dev] Clip by row / column
    Even Rouault
    even.rouault at spatialys.com
    Tue Jul  8 01:30:25 PDT 2025
that should likely be a mode to add to gdal raster clip. Can you file an
enhancement ticket about that?
Even
Le 08/07/2025 à 08:08, Stephane Goldstein via gdal-dev a écrit :
> Hi. I tried to use the gdal raster today to clip a raster by row and
> column as I used to do with
> gdal_translate -srcwin <xoff> <yoff> <xsize> <ysize>
> But couldn't find the equivalent command. Is it available ?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250708/41a9ccf2/attachment.htm>
