[gdal-dev] ADBC driver and DuckDB on Windows
Seth G sethg at geographika.co.uk
Sat Jul 12 03:45:07 PDT 2025
Hi all,
I'm wondering if anyone has got this working on Windows?
With a test.db the following works fine on a full Linux GDAL Docker image:
docker run -it --name gdal-ubuntu -v D:/Data/GDAL:/data ghcr.io/osgeo/gdal:ubuntu-full-3.11.0 /bin/bash
ogr2ogr out.gpkg test.db
>From the docs https://gdal.org/en/latest/drivers/vector/adbc.html
"Assuming libduckdb.so, libduckdb.dylib or duckdb.dll is available (and it is in a system location, or can be located through LD_LIBRARY_PATH on Linux, DYLD_LIBRARY_PATH on MacOSX or PATH on Windows)."
I'm trying to get this working using GDAL via Conda on Windows. The ADBC driver is isntalled:
gdal vector --formats
# includes ADBC -vector- (ro): Arrow Database Connectivity
I tried downloaded the duckdb.dll from https://duckdb.org/docs/installation/?version=stable&environment=cplusplus&platform=win&download_method=direct&architecture=x86_64 (https://github.com/duckdb/duckdb/releases/download/v1.3.2/libduckdb-windows-amd64.zip) and setting the path:
$env:Path = "D:\Tools\libduckdb-windows-amd64;" + $env:Path
Each time, the following error is returned:
ERROR 1: Unable to open datasource `test.db' with the following drivers.
With a longer command:
ogr2ogr -f parquet overture-vt-addresses.parquet `
	-oo ADBC_DRIVER="D:/Tools/libduckdb-windows-amd64/duckdb.dll" `
	-oo PRELUDE_STATEMENTS="LOAD SPATIAL" `
	-oo PRELUDE_STATEMENTS="LOAD PARQUET" `
	-oo PRELUDE_STATEMENTS="load httpfs" `
	-oo PRELUDE_STATEMENTS="load aws" `
	-oo SQL="select * from read_parquet('s3://overturemaps-us-west-2/release/2025-05-21.0/theme=addresses/type=address/*')'"  ADBC:
Results in:
ERROR 1: AdbcLoadDriver() failed:
ERROR 1: Unable to open datasource `ADBC:' with the following drivers.
I tried various paths for ADBC_DRIVER:
	-oo ADBC_DRIVER="D:/Tools/libduckdb-windows-amd64"
	-oo ADBC_DRIVER="D:\Tools\libduckdb-windows-amd64\duckdb.dll"
Just to note the following works in the Conda environment:
python -c "import ctypes;ctypes.CDLL(r'D:\Tools\libduckdb-windows-amd64\duckdb.dll')"
conda install duckdb doesn't help and `conda install conda-forge::libduckdb` isn't available on Windows.
Thanks for any suggestions,
Seth
