[gdal-dev] Java bindings to gdal/ogr - looking for more developer documentation
Even Rouault
even.rouault at spatialys.com
Fri Jul 18 01:27:59 PDT 2025
Hi Tom,
please file an issue at https://github.com/OSGeo/gdal/issues with your
reproducer snippet
Even
Le 17/07/2025 à 02:28, Tom Moore a écrit :
> Hi Evan
> I seem to still be having problems closing datasets in Java resulting
> in a JVM crash, using gdal-3-13-3_x64 downloaded from the GISInternals
> site. Below is the stack trace information.
> --------------- T H R E A D ---------------
> Current thread (0x000001ffd39932c0): JavaThread "Finalizer" daemon
> [_thread_in_native, id=25140,
> stack(0x000000ba6eb00000,0x000000ba6ec00000) (1024K)]
> Stack: [0x000000ba6eb00000,0x000000ba6ec00000],
> sp=0x000000ba6ebfed60, free space=1019k
> Native frames: (J=compiled Java code, j=interpreted, Vv=VM code,
> C=native code)
> C [gdal.dll+0xc86927]
> Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
> j org.gdal.gdal.gdalJNI.delete_Dataset(J)V+0
> j org.gdal.gdal.Dataset.delete()V+25
> j org.gdal.gdal.Dataset.finalize()V+1
> j java.lang.System$2.invokeFinalize(Ljava/lang/Object;)V+1
> java.base at 21.0.6
> j
> java.lang.ref.Finalizer.runFinalizer(Ljdk/internal/access/JavaLangAccess;)V+115
> java.base at 21.0.6
> j java.lang.ref.Finalizer$FinalizerThread.run()V+29 java.base at 21.0.6
> v ~StubRoutines::call_stub 0x000001ffa369100d
> siginfo: EXCEPTION_ACCESS_VIOLATION (0xc0000005), reading address
> 0xffffffffffffffff
> The crash is happening when the swig delete_Dataset method, called by
> the finalizer, calls into the gdal.dll.
> I tried calling Open() and Close() several times in a row to see if
> this would trigger the problem, like this:
> gdal./AllRegister/();
> Dataset ds = gdal.Open(filename);
> ds.Close();
> ds.Close();
> but that seemed to work ok.
> I also tried open and close sequences, like this:
> ds.Close();
> ds.Close();
> System.gc();
> System.runFinalization();
> This didn't trigger a problem either. I did a few more tests,
> repeating steps of opening a dataset, reading a band, closing the
> dataset, and this didn't do it either.
> If I enable CPL_DEBUG then my pattern of access that causes the crash is:
> GDAL:
> GDALDriver::Create(GTiff,c:/tmp/test1.tif,10,10,1,Int32,000001BCB9893680)
> GDAL: GDALClose(c:/tmp/test1.tif, this=000001BCB9872A90)
> GDAL: GDALOpen(c:/tmp/test1.tif, this=000001BCB98784D0) succeeds as GTiff.
> GDAL: GDALClose(c:/tmp/test1.tif, this=000001BCB98784D0)
> GDAL: GDALOpen(c:/tmp/test1.tif, this=000001BCBE486550) succeeds as GTiff.
> GDAL: GDALOpen(c:/tmp/test1.tif.vat.dbf, this=000001BCBE10D070)
> succeeds as ESRI Shapefile.
> GDAL: GDALClose(c:/tmp/test1.tif.vat.dbf, this=000001BCBE10D070)
> GDAL: GDALClose(c:/tmp/test1.tif, this=000001BCBE486550)
> Around this point the finalizer kicks in and the JVM crashes.
> This is a hard one for me to track down, because I don't know the
> tooling to debug native cpp code from within Java. What I could do is
> insert some debugging statements in to the code to try to see what is
> going on. If you have any suggestions about this I would be happy to
> try it.
> Tom
> On Fri, May 30, 2025, at 5:53 PM, Even Rouault wrote:
>> Le 30/05/2025 à 23:39, Tom Moore a écrit :
>> > Hi Even
>> > I just wanted to update you and provide a record for posterity with
>> > the results of me playing around with gdal/java and resource
>> management.
>> > It appears to me that Dataset objects should not be closed from Java
>> > client code. If you do then often there will be an access violation
>> > (native null pointer) that will crash the JVM. From the dump file the
>> > following stack trace shows the Java code being executed when the
>> > exception occurs:
>> I believe this issue should be fixed in 3.11.0 per
>> https://github.com/OSGeo/gdal/commit/ec4ca7930b48653bb0fac27b59c6c1bf883c45f2
>> Actually historically this was the .delete() method that should be
>> called. The exposition of .Close() is quite recent and was broken (until
>> the above mentioned fix)
>> > java.base at 21.0.6
>> > j
>> > java.base at 21.0.6
>> > So it looks like the swig bindings implement a finalizer to dispose of
>> > the native object when the reference is no longer reachable (nice!).
>> > However it looks like there might not be any protection to prevent bad
>> > things from happening when the Delete method is called more than
>> > once. It appears that in this case that when the finalizer calls
>> > Delete on the Dataset the jvm crashes because the Dataset has already
>> > been closed manually and the resources have already been released.
>> > If I am correct in this conclusions then this is not a problem. If
>> > correct I suggest that either the docs be updated to indicate do not
>> > manually call Delete on the Dataset object, or change the Delete
>> > method code to gracefully handle multiple calls (better choice).
>> > By the way, something to note for the future is that finalizers have
>> > been deprecated since Java 9 (2017). This is described in
>> > https://openjdk.org/jeps/421. Although deprecated, finalizers are
>> > still allowed in modern jdk's and probably will be for a while yet. At
>> > some future time they will be removed. The suggested replacement for
>> > finalizers are cleaners, but they are only available in Java 9+. When
>> > finalizers are removed there will need to be a new set of bindings
>> > that use cleaners. You can probably ignore this problem for a few
>> > more years, but at some point you will need to provide two sets of
>> > Java bindings (one required for Java 8 and earlier, and one required
>> > for some future Java and later).
>> Thanks for the heads up. Seizing the opportunity to remind interesting
>> parties in the GDAL Java bindings that they should not be shy and are
>> welcome to be proactive. On my side, they are very very minimilastically
>> maintained.
>> Even
>> http://www.spatialys.com
>> My software is free, but my time generally not.
> Tom Moore
> Spatial Planning Systems
> 960 Burkes Bluff Lane
> Deep River ON K0J 1P0
> Canada
> Phone: +1 613 584 9354
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250718/1df8b253/attachment.htm>
