[gdal-dev] Errors while creating sozip zarr file
Scott public at postholer.com
Sat Jul 19 09:11:14 PDT 2025
Hey Orik,
If I remember correctly, it's only for gpkg, fgb or shp formats. Other
than that the docs show a 'validate' switch which is more robust than
the 'light' validation that is done.
Scott
On 7/19/25 08:44, Erik Schnetter via gdal-dev wrote:
> I am using GDAL to create a multidimensional zarr file that is sozip
> compressed. I see this error when creating the file:
> ERROR 1: dish_positions.00000000.zarr/zarr.json already exists in ZIP file
> ERROR 8: Open file /vsizip/data/fengine_init_pathfinder/
> cx66_dish_positions.00000000.zarr.zip/dish_positions.00000000.zarr/
> zarr.json to write failed
> Everything is working fine when I do not use sozip compression. I enable
> sozip compression by adding a "/vsizip" prefix to the file name.
> Although there is an error reported on screen, I do not see an error
> code reported by the function creating or closing the multidimensional
> dataset. The resulting file ("*.zarr.zip") is created fine and looks
> almost correct, but all attributes seem to be missing.
> I wonder – is it actually possible to create a zarr file that is sozip
> compressed, given that zarr probably writes to each of its file multiple
> times? If not, what is the preferred way to create a sozip-compressed
> zarr file efficiently?
> Some details:
> I create the dataset (i.e. the file) via
>                  const auto driver_manager = GetGDALDriverManager();
>                  const auto driver = driver_manager-
>  >GetDriverByName("Zarr");
>                  const auto dataset =
> std::unique_ptr<GDALDataset>(driver->CreateMultiDimensional(
>                      full_path.c_str(), root_group_options_c.data(),
> options_c.data()));
> where "full_path" is "/vsizip/data/fengine_init_pathfinder/
> cx66_dish_positions.00000000.zarr.zip/dish_positions.00000000.zarr".
> I then create multiple attributes ("CreateAttribute") and then
>                  const auto mdarray = group->CreateMDArray(meta-
>  >get_name(), dimensions, datatype,
> array_options_c.data());
>                      const bool success = mdarray->Write(
>                          arrayStart.data(), count.data(), nullptr,
> bufferStride.data(), datatype,
>                          frame + datatypesize * meta->offset, frame,
> buffer->frame_size);
> and finish with
>                  const CPLErr err = dataset->Close();
>                  assert(!err);
> The full code is available at <https://github.com/kotekan/kotekan/blob/
> eschnett/updates-2/lib/stages/gdalFileWrite.cpp <https://github.com/
> kotekan/kotekan/blob/eschnett/updates-2/lib/stages/gdalFileWrite.cpp>>.
> -erik
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
