[gdal-dev] dataset with no driver?
Even Rouault
even.rouault at spatialys.com
Tue Jul 22 09:08:52 PDT 2025
Mike,
there are a number of situations where you can get a Dataset not linked
to a driver. Code expecting a Dataset as input should be robust to it
having a null driver.
In your situation, given that small_world.tif is a multiband dataset,
but AsMDArray().AsClassicDataset() returning a single band one, having
GetDriver() report the GTiff driver would not match the expectation that
if Dataset.GetDriver() returns a non null pointer ,then
Dataset.GetDescription() can be passed to GDALOpen() and returns a
dataset that is identical to it.
Even
Le 22/07/2025 à 05:04, Michael Sumner via gdal-dev a écrit :
> Hi, this is new to me - casting from MDIM results in a dataset with a
> null driver:
> ds = gdal.Open("../gdrivers/data/small_world.tif")
> ds.GetRasterBand(1).AsMDArray().AsClassicDataset(0,1).GetDriver()
> (stupid question: )
> It makes sense to me for GTiff which has no MDIM capability, but how
> then does the work get done?
> I noticed by going from truly MDIM netcdf to AsClassicDataset() - I'd
> expected that the NetCDF driver was still involved.
> Does this mean we just have to test for null driver and report <none>
> in that case generally?
> Thanks, Mike
> Michael Sumner
> Ordinary Member, Streets People Love Hobart Association
> Research Software Engineer
> Australian Antarctic Division
> Hobart, Australia
> 0438489030
> e-mail: mdsumner at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250722/e7566ff0/attachment.htm>
