[gdal-dev] [External] : Re: Error on building from master branch on linux
Fengting Chen
fengting.chen at oracle.com
Tue Jul 22 13:07:42 PDT 2025
It doesn’t work for me. I got error in gdal_rat.h for looking for type defined in gdal_priv.h.
[ 0%] Building CXX object frmts/pdf/CMakeFiles/gdal_PDF_core.dir/ pdfdrivercore.cpp.o
In file included from /scratch/gdal/gdal/gcore/gdal_priv.h:47,
from /scratch/gdal/gdal/frmts/pdf/pdfdrivercore.h:16,
from /scratch/gdal/gdal/frmts/pdf/pdfdrivercore.cpp:13:
/scratch/gdal/gdal/gcore/gdal_rat.h:272:51: error: ?~@~XGDALColorTable?~@~Y does not name a type; did you mean ?~@~XGDALColorTableH?~@~Y?
virtual CPLErr InitializeFromColorTable(const GDALColorTable *);
GDALColorTableH
-Fengting
Date: Tuesday, July 22, 2025 at 3:33 PM
To: Fengting Chen <fengting.chen at oracle.com>, gdal dev <gdal-dev at lists.osgeo.org>
Subject: [External] : Re: [gdal-dev] Error on building from master branch on linux
Fengting,
I guess you can workaround the issue by adding a #include "gdal_rat.h" at top of gdal_priv.h (shouldn't be required as GDALExtendedDataType declares a destructor, so I guess your compiler is more demanding than strictly needed)
Even
Le 22/07/2025 à 20:15, Fengting Chen via gdal-dev a écrit :
I got the following error while trying to build gdal using “gcc (GCC) 8.5.0 20210514 (Red Hat 8.5.0-26.0.1)”:
In file included from /usr/include/c++/8/memory:80,
from /scratch/gdal/gdal/port/cpl_error.h:372,
from /scratch/gdal/gdal/gcore/gdal.h:30,
from /scratch/gdal/gdal/gcore/gdal_priv.h:45,
/usr/include/c++/8/bits/unique_ptr.h: In instantiation of ?~@~Xvoid std:: default_delete<_Tp>::operator()(_Tp*) const [with _Tp = GDALRasterAttributeTable]?~@~Y:
/usr/include/c++/8/bits/unique_ptr.h:277:17: required from ?~@~Xstd:: unique_ptr<_Tp, _Dp>::~unique_ptr() [with _Tp = GDALRasterAttributeTable; _Dp = std::default_delete<GDALRasterAttributeTable>]?~@~Y
/scratch/gdal/gdal/gcore/gdal_priv.h:3664:55: required from here
/usr/include/c++/8/bits/unique_ptr.h:79:16: error: invalid application of ?~@~Xsizeof?~@~Y to incomplete type ?~@~XGDALRasterAttributeTable?~@~Y
static_assert(sizeof(_Tp)>0,
gmake[2]: *** [frmts/pdf/CMakeFiles/gdal_PDF_core.dir/build.make:76: frmts/pdf/ CMakeFiles/gdal_PDF_core.dir/pdfdrivercore.cpp.o] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:6099: frmts/pdf/CMakeFiles/gdal_PDF_core. dir/all] Error 2
gmake: *** [Makefile:146: all] Error 2
Any idea how to fix this?
Thanks,
-Fengting
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev<https://urldefense.com/v3/__https:/lists.osgeo.org/mailman/listinfo/gdal-dev__;!!ACWV5N9M2RV99hQ!JGfpKPUg6eOXwOKEAFWSuQs31iI5ndeQvAfKRvXm2e_wb77Lm3oMBqWdlfsZNQMRfTQWdNVVdo8sfD6qXQVa22yZjcRH$>
http://www.spatialys.com<https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!JGfpKPUg6eOXwOKEAFWSuQs31iI5ndeQvAfKRvXm2e_wb77Lm3oMBqWdlfsZNQMRfTQWdNVVdo8sfD6qXQVa28qPEEP7$>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250722/3dc2fa9d/attachment-0001.htm>
