[gdal-dev] [External] : Re: Error on building from master branch on linux
Even Rouault even.rouault at spatialys.com
Wed Jul 23 13:58:50 PDT 2025
Le 23/07/2025 à 22:51, Fengting Chen a écrit :
> Hi Even,
> After resolving error on “GDALRasterAttributeTable” by adding
> “gdal_rat.h” to gdal_priv.h, the compilation failed again.
> The compiler on my machine was working fine with GDAL on the master
> branch this early May.  Could there be anything changed in the GDAL
> master that caused the compilation failure?
yes, the addition of std::unique_ptr<GDALRasterAttributeTable>
m_poRAT{}; at line 3664 of gdal_priv.h
You should try to update to a more recent compiler.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250723/53f88321/attachment.htm>
