[gdal-dev] [External] : Re: Error on building from master branch on linux
Fengting Chen
fengting.chen at oracle.com
Wed Jul 30 14:27:43 PDT 2025
Hi Even,
It didn’t help. I got the similar error:
In file included from /usr/include/c++/8/memory:80,
from /scratch/gdal/gdal/port/cpl_error.h:372,
from /scratch/gdal/gdal/gcore/gdal.h:30,
from /scratch/gdal/gdal/gcore/gdalalgorithm.h:19,
from /scratch/gdal/gdal/apps/gdalalg_clip_common.h:16,
from /scratch/gdal/gdal/apps/gdalalg_clip_common.cpp:13:
/usr/include/c++/8/bits/unique_ptr.h: In instantiation of ?~@~Xvoid std:: default_delete<_Tp>::operator()(_Tp*) const [with _Tp = GDALRasterAttributeTable]?~@~Y:
/usr/include/c++/8/bits/unique_ptr.h:277:17: required from ?~@~Xstd:: unique_ptr<_Tp, _Dp>::~unique_ptr() [with _Tp = GDALRasterAttributeTable; _Dp = std::default_delete<GDALRasterAttributeTable>]?~@~Y
/scratch/gdal/gdal/gcore/gdal_priv.h:3668:55: required from here
/usr/include/c++/8/bits/unique_ptr.h:79:16: error: invalid application of ?~@~Xsizeof?~@~Y to incomplete type ?~@~XGDALRasterAttributeTable?~@~Y
static_assert(sizeof(_Tp)>0,
gmake[2]: *** [apps/CMakeFiles/appslib.dir/build.make:90: apps/CMakeFiles/ appslib.dir/gdalalg_clip_common.cpp.o] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:8072: apps/CMakeFiles/appslib.dir/all] Error 2
If I put gdal_rat.h at the top of gdal_priv.h as you suggested before, the build proceeds a little further but failed with the similar error but on a different type:
[ 1%] Building CXX object apps/CMakeFiles/appslib.dir/gdalalg_pipeline.cpp.o
from /scratch/gdal/gdal/apps/gdalalg_pipeline.cpp:13:
/usr/include/c++/8/bits/unique_ptr.h: In instantiation of ?void std::default_del
ete<_Tp>::operator()(_Tp*) const [with _Tp = MEMDataset]?:
/usr/include/c++/8/bits/unique_ptr.h:277:17: required from ?std::unique_ptr<_T
p, _Dp>::~unique_ptr() [with _Tp = MEMDataset; _Dp = std::default_delete<MEMData
set>]?
/scratch/gdal/gdal/apps/gdalalg_vector_pipeline.h:193:38: required from here
/usr/include/c++/8/bits/unique_ptr.h:79:16: error: invalid application of ?sizeo
f? to incomplete type ?MEMDataset?
gmake[2]: *** [apps/CMakeFiles/appslib.dir/build.make:258: apps/CMakeFiles/appsl
ib.dir/gdalalg_pipeline.cpp.o] Error 1
2
Thanks,
-Fengting
Date: Wednesday, July 30, 2025 at 4:08 PM
To: Fengting Chen <fengting.chen at oracle.com>, gdal dev <gdal-dev at lists.osgeo.org>
Subject: Re: [External] : Re: [gdal-dev] Error on building from master branch on linux
Fengting,
would https://github.com/OSGeo/gdal/pull/12830<https://urldefense.com/v3/__https:/github.com/OSGeo/gdal/pull/12830__;!!ACWV5N9M2RV99hQ!IQ-4A2c9x6A3nauMg-dyaTF1RRdUUfXZMhY8McqwBkKoA1G2K5ZeLJ0EN1k3FH38b-mhlkQz8cjr0NROPFZRU4kA4fvI$> help ?
Even
Le 30/07/2025 à 21:35, Fengting Chen a écrit :
Hi Even,
I have been trying to upgrade my compiler to resolve the GDAL compilation issue but without success.
According to the documentation of unique_ptr,
unique_ptr may be constructed for an incomplete type<https://urldefense.com/v3/__https:/en.cppreference.com/w/cpp/language/type-id.html*Incomplete_type__;Iw!!ACWV5N9M2RV99hQ!IQ-4A2c9x6A3nauMg-dyaTF1RRdUUfXZMhY8McqwBkKoA1G2K5ZeLJ0EN1k3FH38b-mhlkQz8cjr0NROPFZRU7ywDM87$> T, such as to facilitate the use as a handle in the pImpl idiom<https://urldefense.com/v3/__https:/en.cppreference.com/w/cpp/language/pimpl.html__;!!ACWV5N9M2RV99hQ!IQ-4A2c9x6A3nauMg-dyaTF1RRdUUfXZMhY8McqwBkKoA1G2K5ZeLJ0EN1k3FH38b-mhlkQz8cjr0NROPFZRU968o7GK$>. If the default deleter is used, T must be complete at the point in code where the deleter is invoked, which happens in the destructor, move assignment operator, and reset member function of unique_ptr.
The error I encountered during the compilation shows that the deleter of GDALRasterAttributeTable was invoked when the type was not complete:
from /scratch/gdal/gdal/gcore/gdal_priv.h:45,
from /scratch/gdal/gdal/frmts/pdf/pdfdrivercore.h:16,
from /scratch/gdal/gdal/frmts/pdf/pdfdrivercore.cpp:13:
/scratch/gdal/gdal/gcore/gdal_priv.h:3664:55: required from here
gmake[2]: *** [frmts/pdf/CMakeFiles/gdal_PDF_core.dir/build.make:76: frmts/pdf/ CMakeFiles/gdal_PDF_core.dir/pdfdrivercore.cpp.o] Error 1
Is there any other way to work around it?
Thanks,
-Fengting
From: Even Rouault <even.rouault at spatialys.com><mailto:even.rouault at spatialys.com>
Date: Wednesday, July 23, 2025 at 4:59 PM
To: Fengting Chen <fengting.chen at oracle.com><mailto:fengting.chen at oracle.com>, gdal dev <gdal-dev at lists.osgeo.org><mailto:gdal-dev at lists.osgeo.org>
Le 23/07/2025 à 22:51, Fengting Chen a écrit :
Hi Even,
After resolving error on “GDALRasterAttributeTable” by adding “gdal_rat.h” to gdal_priv.h, the compilation failed again.
The compiler on my machine was working fine with GDAL on the master branch this early May. Could there be anything changed in the GDAL master that caused the compilation failure?
yes, the addition of std::unique_ptr<GDALRasterAttributeTable> m_poRAT{}; at line 3664 of gdal_priv.h
You should try to update to a more recent compiler.
Even
http://www.spatialys.com<https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!IV0UbTzTiheCT_RtAke5Lf5jehgWvysNhzGSf-s6QzosmATNDjTe2xTp17hAk7QEaHW-P68knUEP-DxLDC1FZG4RX5oU$>
http://www.spatialys.com<https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!IQ-4A2c9x6A3nauMg-dyaTF1RRdUUfXZMhY8McqwBkKoA1G2K5ZeLJ0EN1k3FH38b-mhlkQz8cjr0NROPFZRUwjBn9F2$>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250730/09876118/attachment-0001.htm>
