[gdal-dev] WG: Wrong results during translate input.tif file to output.xyz file with gdal_translate.exe
    Rahkonen Jukka
    jukka.rahkonen at maanmittauslaitos.fi
    Mon Jun  2 01:56:50 PDT 2025
Run:
gdalinfo input.tif -stats
See among other information:
Band 1 Block=1905x1 Type=Float32, ColorInterp=Gray
  Minimum=643.147, Maximum=927.145, Mean=735.006, StdDev=69.669
  NoData Value=-3.402823e+38
  Metadata:
    STATISTICS_MINIMUM=643.14666748047
    STATISTICS_MAXIMUM=927.14501953125
    STATISTICS_MEAN=735.00611216951
    STATISTICS_STDDEV=69.669350319879
    STATISTICS_VALID_PERCENT=48.23
It means that 100-48.23=51.77 percent of the pixels are nodata, and nodata pixels have a value -3.402823e+38.
You must just tell in your next processing steps that your .xyz file contain also nodata values, just like the original data.
-Jukka Rahkonen-
________________________________________
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> käyttäjän Marián Hadri via gdal-dev <gdal-dev at lists.osgeo.org> puolesta
Lähetetty: Maanantai 2. kesäkuuta 2025 11.37
Vastaanottaja: Javier Jimenez Shaw <j1 at jimenezshaw.com>; gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] WG: Wrong results during translate input.tif file to output.xyz file with gdal_translate.exe
Hallo, excuse me, this is the correct link ...https://d.rib-software.com/iTWO_civil/gdaltmp/input.tifBest regards, Marian HadriMarián Hadri  DeveloperE-Mail  Marian.Hadri at rib-software.comTelefon  +49(711)7873-339[X]RIB Software GmbH | Epplestraße 225, Haus 2, 70567 Stuttgart, GermanySitz Stuttgart. Amtsgericht Stuttgart HRB 783426. Geschäftsführer: René Wolf, Tobias Hamacher.
