[gdal-dev] Linking issue in Windows
Daniel Perez Rodriguez
dpr.1980 at gmail.com
Mon Jun 2 02:09:32 PDT 2025
Good morning everyone.
My name is Daniel (first message here) from Spain so I hope I can explain
my problem properly.
I am working in a C++ project, using gdal in Windows and getting it from
vcpkg, using cmake and Visual Studio 2022.
>From the last days, after an update of my development machine I am having a
blocking issue compiling the project, to be a bit more precise: a linking
issue. Here is my configuration and at the end I will put the errors:
*DEVELOPMENT ENVIRONMENT:*
Microsoft Visual Studio Professional 2022 Version 17.13.6
VisualStudio.17.Release/17.13.6+35931.197
Microsoft .NET Framework Version 4.8.09032
Installed Version: Professional
Microsoft Visual C++ 2022
ASP.NET and Web Tools 17.13.124.35287
Azure App Service Tools v3.0.0 17.13.124.35287
C# Tools 4.13.0-3.25167.3+73eff2b5de2ad38ec602c0a9e82f9125fb85992b
C# components used in the IDE. Depending on your project type and settings,
a different version of the compiler may be used.
GitHub Copilot 17.13.444.19527
GitHub Copilot is an AI pair programmer that helps you write code faster
and with less work.
Linux Core Dump Debugging 1.0.9.35825
Enables debugging of Linux core dumps.
Microsoft JVM Debugger 1.0
Provides support for connecting the Visual Studio debugger to JDWP
compatible Java Virtual Machines
NuGet Package Manager 6.13.2
NuGet Package Manager in Visual Studio. For more information about NuGet,
visit https://docs.nuget.org/
Qt Visual Studio Tools 3.3.1.1
This official Qt Group extension, Qt Visual Studio Tools, integrates Qt
development tools into Microsoft Visual Studio 2022, enabling developers to
use their familiar Windows environment without worrying about Qt-related
build steps or tools.
SonarQube for Visual Studio 8.16.0.12791
SonarQube for Visual Studio is an extension to your favorite IDE that
provides on-the-fly feedback to developers on new bugs and quality issues
injected into their code.
TypeScript Tools 17.0.31211.2001
TypeScript Tools for Microsoft Visual Studio
Visual Basic Tools
Visual Basic components used in the IDE. Depending on your project type and
settings, a different version of the compiler may be used.
Visual C++ for Linux Development 1.0.9.35825
Visual Studio IntelliCode 2.2
AI-assisted development for Visual Studio.
*VCPKG.JSON* (special attention please to gdal and proj entries)
"version": "0.0.0",
"builtin-baseline": "6f29f12e82a8293156836ad81cc9bf5af41fe836",
"dependencies": [
{"name": "boost-date-time", "version>=": "1.86.0"},
{"name": "boost-fiber", "version>=": "1.86.0"},
{"name": "boost-filesystem", "version>=": "1.86.0"},
{"name": "boost-geometry", "version>=": "1.86.0"},
{"name": "boost-headers", "version>=": "1.86.0"},
{"name": "boost-iostreams", "version>=": "1.86.0"},
{"name": "boost-property-tree", "version>=": "1.86.0"},
{"name": "boost-regex", "version>=": "1.86.0"},
* {"name": "gdal", "version>=": "3.10.0", "default-features": false},*
{"name": "gtest", "version>=": "1.15.2"},
{"name": "libgeotiff", "version>=": "1.7.3"},
{"name": "lodepng", "version>=": "2021-12-04"},
{"name": "nlohmann-json", "version>=": "3.11.3"},
* {"name": "proj", "version>=": "9.5.1", "default-features": false},*
{"name": "rapidxml", "version>=": "1.13#7"},
{"name": "shapelib", "version>=": "1.6.1"},
{"name": "sqlite3", "version>=": "3.48.0"},
{"name": "units", "version>=": "2.3.3"},
{"name": "zlib", "version>=": "1.3.1"}
*ERROR OUTPUT:*
44> Creating library C:/Users/*****/Release/project.lib and object
C:/Users/*****/Release/project.exp
44>proj.lib(vgridshift.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>proj.lib(oputils.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>proj.lib(concatenatedoperation.cpp.obj) : error LNK2001: unresolved
external symbol __std_search_1
44>proj.lib(coordinateoperationfactory.cpp.obj) : error LNK2001: unresolved
44>proj.lib(datum.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>proj.lib(crs.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>proj.lib(singleoperation.cpp.obj) : error LNK2001: unresolved external
44>proj.lib(internal.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>proj.lib(io.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>proj.lib(factory.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>gdal.lib(ogrdxf_leader.cpp.obj) : error LNK2001: unresolved external
44>proj.lib(4D_api.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>proj.lib(c_api.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>proj.lib(grids.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>gdal.lib(parsexsd.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>gdal.lib(ogrpgdumplayer.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(ogrjsonfgwritelayer.cpp.obj) : error LNK2001: unresolved
44>gdal.lib(ogrdxf_dimension.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(cbandinterleavedchannel.cpp.obj) : error LNK2001: unresolved
44>gdal.lib(asciitiledir.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(binarytiledir.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(gmlreader.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>gdal.lib(cpcidskblockfile.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(ogrwaspdatasource.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(ogrgmldatasource.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(ogrgeojsonutils.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(envidataset.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(cpl_vsil_abstract_archive.cpp.obj) : error LNK2001: unresolved
44>gdal.lib(gdalargumentparser.cpp.obj) : error LNK2001: unresolved
44>gdal.lib(gtiffsplitbitmapband.cpp.obj) : error LNK2001: unresolved
44>gdal.lib(pdfcreatecopy.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(marfa_dataset.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(mrfdrivercore.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(zarr_v2_group.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(vrtderivedrasterband.cpp.obj) : error LNK2001: unresolved
44>gdal.lib(pcidskcreate.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(pdsdrivercore.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(ogr_srs_erm.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(gdalpamproxydb.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(ogrcurvecollection.cpp.obj) : error LNK2001: unresolved
44>gdal.lib(gdalsubdatasetinfo.cpp.obj) : error LNK2001: unresolved
44>gdal.lib(gtiffdataset_read.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(cpl_vsi_mem.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(cpl_vsil_gzip.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(ogrgeometrycollection.cpp.obj) : error LNK2001: unresolved
44>gdal.lib(ogrutils.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>gdal.lib(mrf_util.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>gdal.lib(deriveddataset.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(stacitdataset.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(snaptiffdriver.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(vicardataset.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(gribdataset.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(esric_dataset.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(safedataset.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(cplstring.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>gdal.lib(ogrspatialreference.cpp.obj) : error LNK2001: unresolved
44>gdal.lib(pdsdataset.cpp.obj) : error LNK2001: unresolved external symbol
__std_search_1
44>gdal.lib(pds4dataset.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(marfa_dataset.cpp.obj) : error LNK2019: unresolved external
symbol __std_find_last_of_trivial_pos_1 referenced in function "enum CPLErr
__cdecl GDAL_MRF::Init_Raster(struct GDAL_MRF::ILImage &,class
GDAL_MRF::MRFDataset *,struct CPLXMLNode *)" (?Init_Raster at GDAL_MRF
@@YA?AW4CPLErr@@AEAUILImage at 1@PEAVMRFDataset at 1@PEAUCPLXMLNode@@@Z)
44>proj.lib(filemanager.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(ilwisdataset.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(grddataset.cpp.obj) : error LNK2001: unresolved external symbol
44>gdal.lib(vrtderivedrasterband.cpp.obj) : error LNK2019: unresolved
external symbol __std_find_end_1 referenced in function "char const *
__cdecl std::_Find_end_vectorized<char const ,char const >(char const *
const,char const * const,char const * const,unsigned __int64)"
(??$_Find_end_vectorized@$$CBD$$CBD at std@@YAPEBDQEBD00_K at Z)
44>gdal.lib(gdal_mdreader.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(ogrdxflayer.cpp.obj) : error LNK2001: unresolved external
44>gdal.lib(ogropenfilegdblayer_write.cpp.obj) : error LNK2019: unresolved
external symbol __std_search_2 referenced in function "wchar_t const *
__cdecl std::_Search_vectorized<wchar_t const ,wchar_t const >(wchar_t
const * const,wchar_t const * const,wchar_t const * const,unsigned
__int64)" (??$_Search_vectorized@$$CB_W$$CB_W at std@@YAPEB_WQEB_W00_K at Z)
44>gdal.lib(gnmgraph.cpp.obj) : error LNK2019: unresolved external symbol
__std_remove_8 referenced in function "__int64 * __cdecl
std::_Remove_vectorized<__int64,__int64>(__int64 * const,__int64 *
const,__int64)" (??$_Remove_vectorized at _J_J@std@@YAPEA_JQEA_J0_J at Z)
44>C:/Users/*****/Release/project.exe : fatal error LNK1120: 5 unresolved
externals
Libraries coming from VCPKG and the ones from the project are correctly
built but the final linkage fails.
So any hint about where these "error LNK2001: unresolved external symbol
__std_search_1" came from ?
Thanks in advance !
PS: sorry if this is not the correct channel to communicate these doubts
and correct me in that case.
PPS: don't hesitate for any further information if you need it.
*Daniel Pérez Rodríguez*
*daniteleco.github.io <http://daniteleco.github.io>*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250602/f997572e/attachment-0001.htm>
