[gdal-dev] gdal CLI issues
    Scott
    public at postholer.com
    Tue Jun  3 22:00:35 PDT 2025
GDAL 3.11.0 built from source. Debian 12, bash version: 5.2.15(1)-release:
For every gdal cli command I use, it ends with this message:
Unexpected exception: std::get: wrong index for variant
Also, I cannot get --format=json to work with any vector format. It
works with raster. It's also the default and doesn't work when omitted.
Here are some commands I've been using that DON'T work:
gdal info --format=json -i file.gpkg
gdal vector info --format=json -i file.gpkg
gdal info --format=json --input=file.fgb
gdal vector info --format=json --input=file.fgb
If I change the format to 'text' or use 'raster' with a raster file, it
works fine. ogrinfo works fine also:
ogrinfo -json file.gpkg
Thank you!!!
