[gdal-dev] gdal CLI issues
Scott
public at postholer.com
Wed Jun 4 09:43:13 PDT 2025
You were right Jukka, it was my build.
All is well and having fun with CLI.
On 6/4/25 01:03, Rahkonen Jukka wrote:
> Hi,
> Maybe the right question is why your build yielded a non-working CLI. If you want to test the new gdal CLI tools meanwhile, you can try conda. However, when I just tried to install GDAL on my Windows machine with
> conda install -c conda-forge gdal
> it does not work due to missing "MSVCP140D.dll"
> I think that the "D" there stands for "debug". Does it mean that the conda build is done in a wrong way or what?
> -Jukka Rahkonen-
> ________________________________________
> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> käyttäjän Scott via gdal-dev <gdal-dev at lists.osgeo.org> puolesta
> Lähetetty: Keskiviikko 4. kesäkuuta 2025 8.00
> Vastaanottaja: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> Aihe: [gdal-dev] gdal CLI issues
> GDAL 3.11.0 built from source. Debian 12, bash version: 5.2.15(1)-release:
> For every gdal cli command I use, it ends with this message:
> Unexpected exception: std::get: wrong index for variant
> Also, I cannot get --format=json to work with any vector format. It
> works with raster. It's also the default and doesn't work when omitted.
> Here are some commands I've been using that DON'T work:
> gdal info --format=json -i file.gpkg
> gdal vector info --format=json -i file.gpkg
> gdal info --format=json --input=file.fgb
> gdal vector info --format=json --input=file.fgb
> If I change the format to 'text' or use 'raster' with a raster file, it
> works fine. ogrinfo works fine also:
> ogrinfo -json file.gpkg
> Thank you!!!
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
