[gdal-dev] Buffer in geodetic space
Schumacher, Mia miaschu at gmx.de
Fri Jun 20 03:31:07 PDT 2025
Hi Javier,
there is a QGIS plugin called 'Beeline' that measures great circle
distances: https://plugins.qgis.org/plugins/Beeline/
Hope that helps?
Cheers,
Mia
On 20.06.25 12:06, Javier Jimenez Shaw via gdal-dev wrote:
> Hi
> Yesterday I read an article in a newspaper with an image showing
> distances from a country that was not considering that the Earth is
> spheric. It is not the first time; it will not be the last one. As we
> all (should) know, measuring large distances (thousands of kilometers)
> in projected coordinates is wrong.
> Is there any way to do it properly in GDAL or QGIS? What I mean is
> that the distance (in meters) for a buffer (or parallel line) is
> measured along greatest circles perpendicular to the source geometry.
> If not, should we implement it somewhere? (GDAL, QGIS, somewhere else)
> I guess that we need PROJ for that algorithm to compute the distance
> along a great circle.
> Thanks
> Javier
> PS trying in QGIS, I see it uses ST_Buffer from an sqlite query. But
> it is not what I am talking about. That is the "wrong" solution for
> large distances.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250620/d026a791/attachment-0001.htm>
