[gdal-dev] gdalinfo -stats on Int64 raster: confusing warning
Denis Rykov rykovd at gmail.com
Sat Jun 21 15:14:51 PDT 2025
When I run gdalinfo with -stats options on an Int64 raster, I get the
following warning:
$ gdalinfo -json -stats zzz.tif
Warning 1: GetNoDataValue() returns an approximate value of the true nodata
value = 9223372036854775807. Use GetNoDataValueAsInt64() instead
As an end user, what am I actually supposed to do with this warning?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250622/9d1a3822/attachment.htm>
