[gdal-dev] Read a /vsigzip/ csv.gz all at once
    Joaquim Manuel Freire Luís
    jluis at ualg.pt
    Tue Jun 24 07:33:52 PDT 2025
Im trying to read files like
https://bulk.meteostat.net/v2/hourly/2022/08554.csv.gz
in my Julia wrapper. The point is that, although I'm kind off succeeding, the hole operation is very slow.
What I'm doing (code not committed yet so can't post a link) is to read like this
layer = getlayer(dataset, 0)
for f in layer
               for k = 1: Gdal.nfield(f)
                              Gdal.getfield(f, k-1)
This works but it's extremely slow because each "getfield" takes about 1e-4 seconds and the file has ~8 k rows, each with 13 fields. That amounts to > 10 sec.
I've searched but couldn't find a way to read the entire file at once (which takes 1e-2 seconds if I read it, locally, with a gzip wrapper) and return it as a single string array that I could parse later.
Is that possible?
Thanks
Joaquim
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250624/5bd26729/attachment.htm>
