[gdal-dev] Read a /vsigzip/ csv.gz all at once
    Joaquim Manuel Freire Luís
    jluis at ualg.pt
    Tue Jun 24 09:33:23 PDT 2025
To complement what Eric said, here’s the ‘getfield’ function (This code was taken from ArchGDAL so we are talking of the same thing)
https://github.com/GenericMappingTools/GMT.jl/blob/master/src/gdal.jl#L2161
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Erik Schnetter via gdal-dev
Sent: Tuesday, June 24, 2025 5:21 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Read a /vsigzip/ csv.gz all at once
The Julia wrapper (ArchGDAL.jl) for `getfield` calls `OGR_FD_GetFieldDefn` and several related function (to get the type of the field etc.). Are these possibly expensive operations in GDAL?
Any C function in GDAL can easily be called from Julia. Which C function would get all fields at once? I assume that e.g. `OGR_F_GetFieldAsDoubleList` would not work; this would be for values that are themselves lists?
The Julia code for `getfield` spends quite a bit of work to find out the type of the field. This includes a bit of reference counting, allocating small structures on the heap, registering finalizers for them etc. This could be avoided by adding a Julia wrapper that calls `getfield` repeatedly (even from Julia, calling C has no overhead by itself) for a range of integers. This would avoid the additional overhead having to do with handling types, and the Julia/GDAL reference counting. Even, is that what you had in mind?
-erik
On Jun 24, 2025, at 11:01, Even Rouault via gdal-dev <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>> wrote:
I don't know anything about Julia but I'd suspect that there must be something particularly slow in the way it interacts with C. For comparison,  "time python3 swig/python/gdal-utils/osgeo_utils/samples/ogrinfo.py  /vsigzip//vsicurl/https://bulk.meteostat.net/v2/hourly/2022/08554.csv.gz  -al > /dev/null" that does essentially your loop, and also prints on stdout, runs in 1.5 seconds (compared to native ogrinfo that runs in 0.7 s). Perhaps you could write a Julia wrapper to get all fields of feature at once and return whatever dictionary or equivalent data structure is idiomatic (and efficient )in Julia ? Also are you sure your Julia wrapper is built with optimization enabled?
Even
Le 24/06/2025 à 16:33, Joaquim Manuel Freire Luís via gdal-dev a écrit :
Im trying to read files like
in my Julia wrapper. The point is that, although I’m kind off succeeding, the hole operation is very slow.
What I’m doing (code not committed yet so can’t post a link) is to read like this
layer = getlayer(dataset, 0)
for f in layer
               for k = 1: Gdal.nfield(f)
                              Gdal.getfield(f, k-1)
This works but it’s extremely slow because each “getfield” takes about 1e-4 seconds and the file has ~8 k rows, each with 13 fields. That amounts to > 10 sec.
I’ve searched but couldn’t find a way to read the entire file at once (which takes 1e-2 seconds if I read it, locally, with a gzip wrapper) and return it as a single string array that I could parse later.
Is that possible?
Thanks
Joaquim
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com<http://www.spatialys.com/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250624/0a1ae22b/attachment-0001.htm>
