[gdal-dev] Building GDAL from VCPKG fails with FreeXL
    Even Rouault
    even.rouault at spatialys.com
    Sun Jun 29 02:32:47 PDT 2025
Martin,
what error messages did you get when trying with FreeXL ?
Removing the FreeXL dependency removes support for the old
prior-to-Excel-2007 binary XLS format. So usually not a big deal
Even
Le 29/06/2025 à 02:45, Martin Chapman via gdal-dev a écrit :
> All,
> I tried to build GDAL 3.11.0 from https://vcpkg.io/en/package/gdal and
> FreeXL kept failing on my Windows 11 box using Microsoft Visual Studio
> Professional 2022 (64-bit) – Current Version 17.14.7.  To resolve the
> issue I built a custom-overlay port and removed FreeXL from the build
> and then everything built great.  I tried to just build FreeXL using
> VCPKG and that failed so I was wondering if it’s just my machine that
> is messed up or are others having issues as well?  By removing FreeXL
> will I be crippling any other drivers that may depend on it?  I looked
> at the docs and it didn’t seem that important?  Also, is there a way
> to specify what drivers not to build without doing a custom-overlay port?
> Best regards,
> Martin Chapman
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250629/e3a8ae1e/attachment.htm>
